[Qgis-user] Readonly gpkg
    Nyall Dawson
    nyall.dawson at gmail.com
    Tue Jan 11 17:46:11 PST 2022
On Wed, 12 Jan 2022 at 11:40, Greg Troxel <gdt at lexort.com> wrote:
> Nyall Dawson <nyall.dawson at gmail.com> writes:
> > On Wed, 12 Jan 2022 at 11:00, Greg Troxel <gdt at lexort.com> wrote:
> >> <pergler at gmail.com> writes:
> >> > A. Ideally WAL/DELETE would be a connection (in the sense of the
> >> > Browser connections list) level decision changeable by the user, not a
> >> > layer-level decision and not (as now) an application setting used for
> >> > all gpkg connections.
> >> Fundamentally WAL/DELETE is a (changeable) property of an sqlite3 file,
> >> and thus of a geopackage container.  So exposing it as a db browser
> >> property and allowing it to be changed, with a warning that it is a DB
> >> Admin operation, not a connection operation, seems ok.
> > Instead of exposing this as a per-workstation, QGIS only property, I'd
> > propose instead that the property be set somewhere in the gpkg
> > metadata itself, so that regardless of which user opens it in a
> > multi-user environment, they'll always get the property set by the db
> > administrator. (Maybe this could even become a future formal gpkg
> > extension...?)
> Right now, I think WAL/DELETE is a property of the sqlite3 file which
> contains the geopackage data.  But it's a sqlite3 property, not a
> geopackage property.  (And qgis whacks it on every open.)
> If I am following, you are suggesting a geopackage-level property (in
> some table?), and a rule that when a reader or write opens the file, if
> the sqlite3 setting does not match, the sqlite3 setting is forced and an
> error is logged?
That's correct, but without the error logging.
Nyall
