[Qgis-user] loading geologic symbol library
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Jan 13 05:04:01 PST 2022
Hi Benoit,
sorry for the confusion. I specifically refer to your answer and the
linked project. There is a svg-folder and a folder with the xml-files
from the download.
Setting the path to the svg-folder and then importing the xml is simply
not successful.
As you refered to this project, I assumed that you successfully imported
those styles.
Cheers,
Bernd
Am 13.01.22 um 13:56 schrieb info:
> Hi Bernd,
> Thanks for your comments. It seems I've misread Byron's problem and
> assumed that his library is wrapped up into an xml file!
> In order to use the solution I've provided you need to have an xml
> "library" file describing the .svg files.
> Then you point *Settings -> Style Manager... -> Import/Export ->
> Import Item(s)...*to the xml file not the svg files.
> @Byron, open one of your svg files with a text editor. Does the first
> line starts with "<svg" or is it '<?xml version="1.0" encoding="UTF-8"
> standalone="no"?>'?
> If not you probably have downloaded html files embedding svg images!
> Cheers,
> Benoit
> On 13/01/2022 14:32, Bernd Vogelgesang wrote:
>> Hi Benoit,
>> I just tried to import the symbols from the page you mentioned which
>> leads to this repository: https://github.com/BC-Consulting/FGDC-4-QGIS/
>> Now, even with all explanations given, the import seems not to work
>> properly.
>> no matter what path I add for the FDGC folder (just the .../FDGC or
>> the .../FDGC/svg path) , on import, it says, that
>> - the symbols are already there and gives the option to overwrite or
>> skip,
> This is "normal" behaviour, so just say "overwrite"
>> - the option to add comma-separted tags (e.g. Geology) does not work,
>> and no tag at all is given
>> - all symbols are just question marks
>> Are those guidelines just precisely unprecise, or am I just to dumb
>> to understand whats asked from me?
>> Cheers
>> Bernd
>> Am 13.01.22 um 07:56 schrieb info:
>>> Hi Byron,
>>> *Settings -> Style Manager... -> Import/Export -> Import Item(s)...*
>>> See https://www.geoproc.com/be/qgis-fgdc.htm for more info.
>>> Best regards,
>>> Benoit
>>> On 12/01/2022 23:12, Firstname Lastname wrote:
>>>> i have download a geologic symbol library from Rod Holcolme, a
>>>> geology prof in australia.  i have set up the path for the files
>>>> via the Options>system>.svg path.
>>>> this seems to have linked to the directory, but i can not figure
>>>> out how to see the files.
>>>> within the directory, there are several files that show up as
>>>> microsoft edge html files with the file types as shown below.
>>>> GeoQSymbols/DipDir/001%20Bedding%20(dipdir).svg
>>>> Can anyone help me to get these imported.  i can not get them
>>>> imported .
>>>> thanks for your help
>>>> Byron Veilleux, MSc. P.Geo
>>>> Conjugate Geologic Services Limited
>>>> Calgary, Alberta Canada
>>>> byron at conjugategeo.com
>>>> Cell:4037108414
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220113/48654ab1/attachment.html>
