[Qgis-user] Readonly gpkg
Greg Troxel
gdt at lexort.com
Thu Jan 13 08:51:12 PST 2022
Even Rouault <even.rouault at spatialys.com> writes:
>> I think the simplest and safest change is to remove all code that
>> changes the journal mode as a side effect of access. People that want
>> WAL can pragma it on, with DBA hat on. In my view sqlite's WAL option
>> breaks the previous concept that you can have a database without
>> understanding databases, and as long as it's a DBA choice, that's ok.
> WAL is really a programmer level concept. I'm not sure a QGIS advanced
> user/admin should be aware of that.
I think it's a DBA-level concept. And perhaps it's reasonable to let
QGIS have a tool to let DBAs configure things.
>> Separately from the "DBA chooses journal mode" view, I feel that
>> constantly flipping the journal mode is asking for trouble. I suppose
>> one could write a test with N processes that each connect, set a random
>> choice of WAL or DELETE, wait a bit, do a transaction to increment a
>> value, perhaps repeat that, and then if they set WAL set DELETE and
>> exit, as a way to look for races. Maybe sqlite3's own tests already do
>> that.
> If you do no turn WAL on when editing, the following QGIS tests will
> fail (and some real world situations like where you have a huge layer
> being refreshed in the background while trying to edit it):
> https://github.com/qgis/QGIS/commit/b6b8759efbeb833d0d3dbf6df008087701361ad3#diff-56354e2446fe2cb6d1ee92d4e984091172e964e90f3be4d3d42276e033c4986eR92
I don't immediately grasp that, but it seems wrong to say that a
particular journal mode needs to be used to get the right behavior. As
I read the sqlite3 docs, the journal mode should only affect efficiency,
not correctness, and sqlite3 should provide the same semantics
guarantees in both cases.
So I think this is evidence of a bug someplace in QGIS/GDAL/sqlite3, and
switching to WAL is a workaround, not a fix.
I don't think it's reasonable to always flip WAL on, because per the
docs WAL is only sound if there is no remote access, plus it breaks the
reads-do-not-write property. I realize qgis checks if *it* is accessing
locally, but it cannot know that nobody else will access the same
geogpackage file over a remote file system. Only the DBA can know that
this is not part of the larger operational config/plan.
The underlying big issue here is that sqlite3 sort of offers to let
people use databases without understanding them, and without having some
clue in a DBA role, like you'd expect with a postgis/postgresql setup.
But it seems that once there is any WAL, sqlite3 usage is not longer in
the "does not need to be understood" category. That's a lot of why I
favor "let the DBA turn on WAL if they want, and don't change it
programmatically by default'.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220113/0ad2092b/attachment.sig>
