[Qgis-user] Hstore in temporary layer?
Thayer Young thayeray at yahoo.com
Thu Jan 13 13:41:28 PST 2022
 I think this would be a feature request, I do not see it in the Github issues. It would be nice to be able to use hstore in temporary layers. If I add a field to a temporary layer I am not given the option of hstore in the data type selection, so I assume the answer to your question is no it is not implemented.
As a frequent user of OpenStreetMap extracts I have the same question, hopefully others will give you feedback on the status of this.
There is a workaround which you likely have already discovered. You can fool QGIS by casting the hstore field to text, e.g. by making a view in PostGIS. You can use the text field as hstore fairly easily in expressions.The problem of course is that if you want to edit the hstore field in your temporary layer, you have to write out the hstore text, you don't get to use the convenient QGIS key value form that QGIS gives for hstore fields.
-Thayer
Message: 3
Date: Thu, 13 Jan 2022 11:45:59 +0100
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] Hstore in temporary layer?
Message-ID: <aceaa56a-c287-3457-934d-12d0ec570135 at gmx.de>
Content-Type: text/plain; charset=UTF-8
Hi all,
I wanted to paste some features from PostgreSQL as new temporary layer,
but QGIS complains "WARNING    Objekte einf?gen : Konnte Feld tags
(hstore,QVariantMap) nicht anlegen". Is this not implemented?
Kai Borgolte, Bonn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220113/1278765e/attachment.html>
