[Qgis-user] Mosaic Datasets and Raster Catalogs in qGIS
Zoltan
zoltans at geograph.co.za
Fri Jan 14 12:49:26 PST 2022
Hi Jason,
You just need to create a VRT.
The vrt is just that: a virtual raster table.
Fiddle with the options and notice that you can mix rasters that have differing projection.
Test out on maybe a 100 or so Raster files and when you get the feel for it, dump the lot in. I've had >5000 files in one with no hassles.
Note that if you output your vrt file into the same folder as your rasters, when you recreate your vrt, it will read in your old one and go into a loop.
I logged this as a bug and was told unceremoniously that it was not a bug.
Btw, when you first load your vrt into qgis, have rendering turned off.
Then set your zoom display scales before turning rendering on again. This will stop qgis from trying to display all your tasters if you happen to be zoomed out too far.
Have fun, it works well.
Regards
Zoltan
Sent from BlueMail
On 14 Jan 2022, 21:45, at 21:45, Jason Aleksi <jason.aleski at gmail.com> wrote:
>I am trying to add imagery in qGIS. In ArcMap, I had to create a
>Mosaic
>Dataset, then a Raster Catalog. It tooks days to create due to the
>large
>files and quantity of files. I have 6 inch imagery of a county in a
>folder. The GeoTIFFs are about 308GB in size and approx 6,610 files
>(TIF
>and TIFW). When I attempt to create a raster layer, it will only pull
>in
>100 images.
>Will I have to create 305 Layers with 100 images each? Or is there a
>better way? I'm at a loss for terms to even search for. I feel I've
>exhausted Google! If there is a better way, could you possibly point
>me in
>the right direction?
>FTW: I also have MrSID Tiles and Composites, in a separate directory.
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220114/1c586e0d/attachment.html>
