[Qgis-user] Update Null Geometry
Hugh Kelley
hghklly at gmail.com
Thu Jan 20 08:17:26 PST 2022
Beautiful, thank you both!
On Thu, Jan 20, 2022 at 11:14 AM Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Hi Hugh,
> Are you working with a CSV file? Or is it a shapefile?? Im not sure if
> this will work, but create a new point for a null geomety, you can then,
> using the Attribute table (in edit mode), *Merge Features*, by selecting
> the new geometry and the table row without geometry, then selecting *Merge
> Features* The popup will then allow you to merge the two, you can select
> the row without geometry and select “*Take attributes from selected
> feature*” this should merge your new geometry with the attribute.
> Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> *FRM Data Management*
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Hugh
> Kelley
> *Sent:* 20 January 2022 16:01
> *To:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Update Null Geometry
> Hi all,
> I have a points dataset with a few null geometries in it.
> Is there a tool that can update these in place?
> It seems that the point editing tool must add a new row instead of
> updating an existing row.
> The vertex editing tool seems unable to update a null geom since there's
> nothing to initially click on.
> Maybe I'm missing a tool or way of using the vertex editing tool?
> A less preferred workflow would be to create a separate file and manually
> add the points with the primary key as an attribute to later update on in
> postgres but it would be much cleaner to edit the table in place I think
> and I am curious if there is a solution since I'm not thinking anything up
> myself.
> Thanks for any suggestions.
> Hugh Kelley
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/76536c11/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/76536c11/attachment.png>
