[Qgis-user] R: Raster .asc and .nc wrong projection
Eugenio Trumpy
frippe12573 at hotmail.com
Fri Jan 28 14:52:42 PST 2022
Hi John,
thanks for your hints.
I downloaded the version you suggested.
It works, however, I got the same error when I load a saved project,
but fortunatelly the raster are well located.
I'll wait for the 3.22.4 to have the bugs solved.
Do you think the same issue could exists in qgis-server?
It happens that raster well visualised in 3.22.2 desktop
seems to be not well georeferenced in qgis-server 3.22.
In particular, raster seems to be stretched toward down.
Very strange,
Eugenio
>Hi Eugenio,
>There are 2 bugs in 3.22.3 that I think you've hit. One is rasters are
>displayed wrong on Mac Retina screens, and the other is with CRS
>transforms. Both are fixed in 3.22.4 due next month, but in the meantime I
>suggest you use 3.22.2 instead to fix the raster problem (
>https://qgis.org/downloads/macos/pr/qgis_pr_final-3_22_2_20211217_134828.dmg
>If the approximate transform error appeared only when creating the new
>project and setting your CRS, then it's not a problem. If it appears when
>opening an old project, then you need to either set the correct transform
>manually, or use 3.16 where this isn't an issue.
>Cheers!
>John.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220128/060349c0/attachment.html>
