[Qgis-user] plugin issue
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sat Jan 29 10:22:46 PST 2022
If you can't get the plugin working, I very strongly recommend using
GeoDa. https://geodacenter.github.io/ It's developed by Dr. Luc Anselin
and his team. This is open source and works with .shp files. A strong
tool to be used with QGIS.
Nicolas
On 2022-01-29 5:06 a.m., froso tsartinoglou wrote:
> I have loaded the visualist plugin, in order to run the spatial
> Autocorrelation (moran), but every time I try to run there is always
> an error message, that I cannot understand. Why is this happening?
> I did the same procedure to a friend's laptop and everything worked
> fine. Maybe I should do something before running it with the
> programm's settings?
> I loaded qgis to another pc and there seems to run the same problem..
> Can you please help me with this?
> Qgis-user mailing list
Nicolas Cadieux
https://gitlab.com/njacadieux
