[Qgis-user] Offline background map for large regions
abru345 at gmx.de abru345 at gmx.de
Wed Jul 20 13:42:53 PDT 2022
Hi Asim,
meanwhile I found out that creating a spatialite database needs (unlike
  postgres) only very little RAM for building. On the other side, after
running a wole day and night on conversion of the  ~30GB osm_europe.pbf
with ogr2ogr, I have a 180 GB database now which needs minutes to load...
Don't know if postgres is more performant. Setup is much more complicated.
Regards,
Andreas
Am 20.07.22 um 03:43 schrieb Asim:
 > On 7/15/22 4:11 PM, Andreas via Qgis-user wrote:
 >> I think postgres itself is not the problem at all, but the scripts that
 >> move the vector tiles into the database. In the instructions for usage
 >> of these import scripts is written that they need at least as much RAM
 >> as the size of the vector file. So I assume it has to load the whole
 >> file into memory before it can be processed.
 > Thank you for the clarification, Andreas.  I'm new to the GIS ecosystem
 > but the OGR FDW seems to be addressing the problem of not having to load
 > entire vector data at once: https://github.com/pramsey/pgsql-ogr-fdw.
 > Asim
