[Qgis-user] Export gpx?
Patrick Dunford
enzedrailmaps at gmail.com
Sun Jul 24 21:40:47 PDT 2022
There is also a limitation to the number of fields that can be stored. I
think it is just limited to name?
On 25/07/22 08:17, Ramon Andinach via Qgis-user wrote:
> Hi David,
> The GPX format is only able to have points and lines. You’ll need to
> convert the polygon into a line first, and there is something in the
> vector menu that will do this.
> (Points map to waypoints, lines map to tracks.)
> Regards,
> Ramon.
>> On 25 Jul 2022, at 03:52, David Witton via Qgis-user
>> <qgis-user at lists.osgeo.org> wrote:
>> I'm trying to transfer the boundary of a property that is displayed
>> in a vector layer in QGIS 3.16.15 into a mapping software. My first
>> thought is to select the row in the attribute table, then export it
>> as a .gpx file.
>> However I'm getting an error "Geometry type of 'Multi Polygon' not
>> supported in GPX.
>> Is what I'm trying to do possible using another format?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220725/aadd50ff/attachment.htm>
