[Qgis-user] Astronomical map
Lester Anderson
arctica1963 at gmail.com
Tue Jun 14 09:27:35 PDT 2022
Quick update. Managed to fix the annotations using an expression in layout:
CASE
WHEN @grid_number < 0 AND @grid_axis ='x'
THEN (@grid_number /-15)
WHEN @grid_number = 0
THEN @grid_number = 24
WHEN @grid_number > 0 AND @grid_axis ='x'
THEN (360 - @grid_number)/15
WHEN @grid_number > 0 AND @grid_axis ='y'
THEN @grid_number
WHEN @grid_number < 0 AND @grid_axis ='y'
THEN @grid_number
END
Based on the east-west being +/- 180 degrees, so we have O (24) hours as
the central meridian. Annotations applied to a 15 degree longitude
graticule.
On Tue, 14 Jun 2022 at 07:20, Lester Anderson <arctica1963 at gmail.com> wrote:
> Hello all,
> I am interested in how one can generate an astronomical map based on Right
> Ascension (RA) and Declination (Dec), without converting RA to degrees and
> reversing (-15 * RA).
> There is the affine transform tool which can be used to scale X and flip,
> but this then generates the 0-360 degree scale. The main issue is that the
> IAU standard is for the RA to start at 24 and run east to 0!
> Any ideas would be most welcome.
> Lester
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220614/19ec2803/attachment.htm>
