[Qgis-user] how to convert a circular string into a standard linestring?
Richard Greenwood richard.greenwood at gmail.com
Tue Jun 14 12:27:37 PDT 2022
Perfect, just what I needed. Thanks so much.
On Tue, Jun 14, 2022 at 1:23 PM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hello Richard,
> Try to use the densify tools from the processing toolbox. Either densify
> by count or densify by interval should work.
> https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#densify-by-count
> The tools can be used as in-place mode, so you can select a specific
> feature are run the tools without creating a new layer.
> Alexandre Neto
> Users support
> www.qcooperative.net
> A terça, 14/06/2022, 19:24, Richard Greenwood via Qgis-user <
> qgis-user at lists.osgeo.org> escreveu:
>> I used the Edit menu function "add Circular String" and got just what I
>> wanted. But how can I convert it into a regular linestring with a bunch of
>> vertices that approximate the curve? Specifically, I need to be able to
>> trace the curve with the Split Features tool and trace it when drawing a
>> polygon.
>> Thanks
>> Richard W. Greenwood
>> www.greenwoodmap.com
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220614/808b295c/attachment.htm>
