[Qgis-user] Symbology
Allan Younger
ahyounger at iinet.net.au
Sat Jun 18 05:29:05 PDT 2022
Hi Kirk,
Yes coming up as text whereas another file of diff data which comes up
fine is "double".
Csv file generated from xlsx file which is my SOP, not happened
previously & been using QGIS for 10yrs+.
Can redo as has been thru a few mods.
Chrs
AY
------ Original Message ------
>From "kirk" <kirk at nortekresources.com>
To "Allan Younger" <ahyounger at iinet.net.au>; "Kobben, Barend (UT-ITC)"
<b.j.kobben at utwente.nl>; "chris hermansen" <clhermansen at gmail.com>
Cc "QGIS User" <Qgis-user at lists.osgeo.org>
Date 18/06/2022 6:03:37 PM
Subject Re: [Qgis-user] Symbology
>If the data is being read as a character versus a integer or decimal,
>you cannot use graduated symbols. Double left click on the layer in the
>legend and select properties. Select the Fields tab and see what format
>the attributes are being read as. I have run into this when generating
>a csv from a spreadsheet from different language. I would convert the
>format in excel or livre office and regenerate the csv file.
>Alternatively you can use text editor to replace the quotes on each
>value in the existing csv.
>Kirk Schmidt
>Sent from my Galaxy
>-------- Original message --------
>From: Allan Younger via Qgis-user <qgis-user at lists.osgeo.org>
>Date: 2022-06-18 3:13 a.m. (GMT-04:00)
>To: "Kobben, Barend (UT-ITC)" <b.j.kobben at utwente.nl>, chris hermansen
>Cc: QGIS User <Qgis-user at lists.osgeo.org>
>Subject: Re: [Qgis-user] Symbology
>csv file
>From "Kobben, Barend (UT-ITC)" <b.j.kobben at utwente.nl>
>To "chris hermansen" <clhermansen at gmail.com>; "Allan Younger"
>Date 18/06/2022 12:32:07 PM
>>Usually this happens if you have numbers (quantitatvie data) that are
>>stored in your file/db as Strings (text)....
>>Barend Köbben
>>On 18/06/2022, 04:25, "Qgis-user on behalf of chris hermansen via
>>Qgis-user" <qgis-user-bounces at lists.osgeo.org on behalf of
>>Qgis-user at lists.osgeo.org> wrote:
>>Allan and list,
>>On Fri, Jun 17, 2022 at 7:00 PM Allan Younger via Qgis-user
>><qgis-user at lists.osgeo.org> wrote:
>>>Hi,
>>>I'm trying to show assay results as simple dot plots as graduated
>>>colour and size scaled points based on a selected element.
>>>Problem is that in the layer properties/symbology tab, I cannot
>>>select anything.
>>>Had the problem in Madeira 3.4 & assumed was just a glitch that had
>>>developed in that copy over time.
>>>Installed 3.22.7, same problem.
>>>Csv file has 162000 records & 30 column with co-ords for every point;
>>>with locations plotting a-ok.
>>At the top of the Layer Properties > Symbology dialogue window, have
>>you selected one of the options other than "No Symbols"? For example,
>>"Graduated"?
>>Then in the field Value one of your layer's attributes?
>>Then pressed the "Classify" button?
>>Chris Hermansen · clhermansen "at" gmail "dot" com
>>C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220618/de3ab2a3/attachment.htm>
