[Qgis-user] polygon fills from different shapefiles
    Firstname Lastname
    byron at conjugategeo.com
    Tue Jun 21 07:46:05 PDT 2022
Ok, thanks.
On Tue, Jun 21, 2022 at 8:43 AM David Strip <qgis-user at stripfamily.net>
wrote:
> On 6/21/2022 8:37 AM, Firstname Lastname via Qgis-user wrote:
> I have gone that far, but I have four sets of maps with similar units.  If
> I categorize them independantly, I have to manually change the colours to
> make them consistent between layers.   This is very time consuming and I
> was wondering if the colour can added to the attribute table so that I can
> edit them more easily
> On Tue, Jun 21, 2022 at 2:56 AM <geo.guide at web.de> wrote:
>> Context menu of your shapefile > properties > choose Tab "Symbology" >
>> select "Categorize" in the first line with the attribute for the name of
>> the geologic formation as the value in the second line. Click on "Classify"
>> and style your polygons as appropriate.
>> Regards, Christine
> Assuming all the shapefiles use the same name for the attribute you will
> use for categorization, you can save the styling to a style file from the
> Symbology tab of the Properties dialog. Do this once, then load the style
> file to the other layers.
Byron Veilleux, MSc. P.Geo
Conjugate Geologic Services Limited
Calgary, Alberta Canada
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220621/17b2455c/attachment.htm>
