[Qgis-user] Dimensioning in QGIS
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Jun 24 02:03:38 PDT 2022
Hi Ian,
the only way I know of visualizing dimensions so far is by using a
special style: https://github.com/faunalia/QGIS-Resources.git
To be able to use it, you have to install the "Resource Sharing"-plugin
and then install "Distance Measurement Styles" from there.
This is a quite clever but also a bit confusing approach, cause the
labels with the numbers are actually no labels in the common sense, but
generated as a font markers within the symbology.
You will have to play around with them to make them look as you like.
It may be good not to use thet style on your original features, but
create a separate dimensioning layer (a duplicate of your orginial layer)
Cheers,
Bernd
Am 23.06.22 um 23:33 schrieb IainS via Qgis-user:
> Is there a tool for adding dimensions in QGIS. For those who are
> wondering what I am talking about, it is common in CAD drafting to add
> dimensions to what you have drawn and this is a whole part of a CAD
> program where you can format dimensions …etc.
> I have been asked to add dimensions to an archaeological hole I am
> digging on a QGIS map and I was wondering whether there is a similar
> dimensioning tool in QGIS.
> Cheers
> *Dr Iain Stuart*
> */JCIS Consultants /*
> P.O. Box 2397
> Burwood North
> NSW, 2134
> (02) 9701 0191
> (0413) 380116 (m)
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/9d221f70/attachment.htm>
