[Qgis-user] reduce resolution of an image in qgis
    Zoltán Siki
    siki1958 at gmail.com
    Fri Jun 24 05:17:28 PDT 2022
you can used grdal translate from the processing  toolbox. You have to add
additional command line parameters, for example  -outtsize 50% 50% to make
pixel double size alternatively you can also use -tr switch to define the
output pixel size e.g. -tr 1.0 1.0 to change the resolution to 1
georeferenced unit of your raster.
Regards,
Zoltan
carlos h via Qgis-user <qgis-user at lists.osgeo.org> ezt írta (időpont: 2022.
jún. 23., Cs, 20:51):
> Hello, I have an NDVI image that has a pixel of 4 centimeters, that is, 16
> square centimeters.
> I have 2 doubts:
> 1. What method can I use to generalize the NDVI image to 1 square meter in
> pixel size?
> 2. When generalizing the NDVI image to 1 square meter per pixel, what
> value does that new pixel take? the mean value of all pixels in 1 square
> meter? the maximum value of the pixels? etc, I ask this because if the
> original NDVI image has a pixel of 4 centimeters (16 cm2), in 1 square
> meter there are more or less 625 pixels, then what pixel value does it take
> if it is generalized to 1 square meter? the average? the maximum value?
> Thank you very much
> Carlos
> Qgis-user mailing list
Üdv.
Siki Zoltán
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/b85cf1fa/attachment.htm>
