[Qgis-user] Dimensioning in QGIS
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Fri Jun 24 09:26:50 PDT 2022
Qgis is not a CAD as you are discovering.  Others have given you good plugins and tools so I will not add to that.  You can still do “3D” as 3D objects like lines, points and polygon are supported.  You can use the 3D map windows to visualize the 3D objects and a DEM  raster or mesh layers.  I too am an archaeologist.  In the past, I have used simple 3D WKT format in a text file to make 3D outlines of trenches and survey holes. Looks like some plugins can now do that for you now.  QGIS is not quite there as a full blown CAD but it’s as good as current Commercial GIS I have worked with.  Progress has been slow but steady.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 24 juin 2022 à 08:03, Zoltán Siki via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> you can solve it using Geometry Generator see: https://stuyts.xyz/2018/11/05/qgis-geometry-generator-examples-repository/
> Regards,
> Zoltan
> IainS via Qgis-user <qgis-user at lists.osgeo.org> ezt írta (időpont: 2022. jún. 23., Cs, 23:44):
>> Is there a tool for adding dimensions in QGIS. For those who are wondering what I am talking about, it is common in CAD drafting to add dimensions to what you have drawn and this is a whole part of a CAD program where you can format dimensions …etc.
>> I have been asked to add dimensions to an archaeological hole I am digging on a QGIS map and I was wondering whether there is a similar dimensioning tool in QGIS.
>> Cheers
>> Dr Iain Stuart
>> JCIS Consultants
>> P.O. Box 2397
>> Burwood North
>> NSW, 2134
>> (02) 9701 0191
>> (0413) 380116 (m)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Üdv.
> Siki Zoltán
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/b41a5f2b/attachment.htm>
