[Qgis-user] Using OS Raster Data in QGIS
    Thayer Young
    thayeray at yahoo.com
    Sat Jun 25 12:36:20 PDT 2022
 Rasters sometimes have more than one file with the same name for each raster. A good rule of thumb is to open the largest file. The documentation for adding rasters to a project will help you with the procedure. The link below is to the current Long Term Release documentation 3.22. 3.8 is quite old.
https://docs.qgis.org/3.22/en/docs/training_manual/rasters/index.html
You may also be using vector data from Ordinance Survey, so from the Data Source Manager click on vector on the left and select Directory for source type and UK.NTF2 from type and then navigate to your data file.
https://gdal.org/drivers/vector/ntf.html#vector-ntf
-Thayer
    On Saturday, June 25, 2022, 12:01:28 PM EDT, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
 Send Qgis-user mailing list submissions to
    qgis-user at lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
    https://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
  1. Re: Dimensioning in QGIS (chris hermansen)
  2. Re: Dimensioning in QGIS (Nicolas Cadieux)
  3. Re: Dimensioning in QGIS (Alexandru Munteanu)
  4. (DEREK Beddis)
  5. Re: Dimensioning in QGIS (David Strip)
Message: 1
Date: Fri, 24 Jun 2022 12:18:13 -0700
To: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Cc: Zolt?n Siki <siki1958 at gmail.com>, Iain at jcis.net.au, qgis-user
    <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Dimensioning in QGIS
Message-ID:
    <CACc2_69p44wVZmToexKn=OJt2yYxDOcV2gAZ_OE52VqN82y0uA at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Nicolas, everyone,
Sorry to top post here but I'm not sure where to start below.
What about just using the various drawing tools on the print layout?
Arrows can be added, annotation, polylines, that sort of thing?  Of course
it's not in the original data / layers, but is that important?
On Fri, Jun 24, 2022 at 9:27 AM Nicolas Cadieux via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> Qgis is not a CAD as you are discovering.  Others have given you good
> plugins and tools so I will not add to that.  You can still do ?3D? as 3D
> objects like lines, points and polygon are supported.  You can use the 3D
> map windows to visualize the 3D objects and a DEM  raster or mesh layers.
> I too am an archaeologist.  In the past, I have used simple 3D WKT format
> in a text file to make 3D outlines of trenches and survey holes. Looks like
> some plugins can now do that for you now.  QGIS is not quite there as a
> full blown CAD but it?s as good as current Commercial GIS I have worked
> with.  Progress has been slow but steady.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 24 juin 2022 ? 08:03, Zolt?n Siki via Qgis-user <
> qgis-user at lists.osgeo.org> a ?crit :
> you can solve it using Geometry Generator see:
> https://stuyts.xyz/2018/11/05/qgis-geometry-generator-examples-repository/
> Regards,
> Zoltan
> IainS via Qgis-user <qgis-user at lists.osgeo.org> ezt ?rta (id?pont: 2022.
> j?n. 23., Cs, 23:44):
>> Is there a tool for adding dimensions in QGIS. For those who are
>> wondering what I am talking about, it is common in CAD drafting to add
>> dimensions to what you have drawn and this is a whole part of a CAD program
>> where you can format dimensions ?etc.
>> I have been asked to add dimensions to an archaeological hole I am
>> digging on a QGIS map and I was wondering whether there is a similar
>> dimensioning tool in QGIS.
>> Cheers
>> *Dr Iain Stuart*
>> *JCIS Consultants *
>> P.O. Box 2397
>> Burwood North
>> NSW, 2134
>> (02) 9701 0191
>> (0413) 380116 (m)
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> ?dv.
> Siki Zolt?n
Chris Hermansen ? clhermansen "at" gmail "dot" com
C'est ma fa?on de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/4161fa7e/attachment-0001.htm>
Message: 2
Date: Fri, 24 Jun 2022 16:20:18 -0400
From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
To: chris hermansen <clhermansen at gmail.com>
Message-ID: <d2774543-bf81-bd5c-ec11-534198f83fd0 at gmail.com>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hi Chris,
Dimensions here are not annotations.? I believe the original post was
referring to what AutoCad refers to as "Extrude" as seen here
https://www.youtube.com/watch?v=PdysbeHHXo8.
Cheer!
Nicolas
On 2022-06-24 3:18 p.m., chris hermansen wrote:
> Nicolas, everyone,
> What about just using the various drawing tools on the print layout??
> Arrows can be added, annotation, polylines, that sort of thing?? Of
> course it's not in the original data / layers, but is that important?
> <qgis-user at lists.osgeo.org> wrote:
>    Hi,
>    Qgis is not a CAD as you are discovering.? Others have given you
>    good plugins and tools so I will not add to that.? You can still
>    do ?3D? as 3D objects like lines, points and polygon are
>    supported.? You can use the 3D map windows to visualize the 3D
>    objects and a DEM ?raster or mesh layers.? I too am an
>    archaeologist.? In the past, I have used simple 3D WKT format in a
>    like some plugins can now do that for you now.? QGIS is not quite
>    there as a full blown CAD but it?s as good as current Commercial
>    GIS I have worked with.? Progress has been slow but steady.
>    Nicolas Cadieux
>>    <qgis-user at lists.osgeo.org> a ?crit?:
>>    Regards,
>>    Zoltan
>>    (id?pont: 2022. j?n. 23., Cs, 23:44):
>>        are wondering what I am talking about, it is common in CAD
>>        drafting to add dimensions to what you have drawn and this is
>>        a whole part of a CAD program where you can format dimensions
>>        ?etc.
>>        I am digging on a QGIS map and I was wondering whether there
>>        is a similar dimensioning tool in QGIS.
>>        Cheers
>>        *Dr Iain Stuart*
>>        */JCIS Consultants /*
>>        P.O. Box 2397
>>        Burwood North
>>        NSW, 2134
>>        (02) 9701 0191
>>        (0413) 380116 (m)
>>    ?dv.
>>    Siki Zolt?n
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/1f6d5bc0/attachment-0001.htm>
Message: 3
Date: Sat, 25 Jun 2022 00:45:06 +0300
From: Alexandru Munteanu <aldru.munteanu at gmail.com>
To: qgis-user at lists.osgeo.org
Cc: chris hermansen <clhermansen at gmail.com>, Iain at jcis.net.au,
Message-ID:
    <CAGzUEjpaQALf_CcyMMU9ZzWk+BQJkC+a3vDN-FRYMUjA_=O85Q at mail.gmail.com>
A workaround I use I in my work is to actually use autocad for drawing the
dimensions (or anything else) and then import a dxf file in qgis, either as
shapes or as a vector layer.
What I do is export a polygon in dxf, draw the dimensions  in autocad and
import it back into qgis. With a little styling, the dimensions will look
exactly the same as in autocad. A tip is to use different layers in autocad
as it's easier to apply styles in qgis afterwards.
Hope this helps,
Alexandru
On Fri, Jun 24, 2022, 23:20 Nicolas Cadieux via Qgis-user <
> Hi Chris,
> Dimensions here are not annotations.  I believe the original post was
> Cheer!
> Nicolas
> Nicolas, everyone,
>> Hi,
>> Nicolas Cadieux
>> Regards,
>> Zoltan
>>> Cheers
>>> *Dr Iain Stuart*
>>> *JCIS Consultants *
>>> P.O. Box 2397
>>> Burwood North
>>> NSW, 2134
>>> (02) 9701 0191
>>> (0413) 380116 (m)
>> ?dv.
>> Siki Zolt?n
> Nicolas Cadieuxhttps://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220625/e64e22e5/attachment-0001.htm>
Message: 4
Date: Sat, 25 Jun 2022 14:38:04 +0000
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Using OS Raster Data in QGIS
Message-ID:
    <DB4PR03MB86583C9776E93340204B0CF4F0B79 at DB4PR03MB8658.eurprd03.prod.outlook.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi, I used QGIS about 4 years ago to produce maps for 1:25,000 and 1:50,000 OS maps, I feel a fool now, but I am struggling to get QGIS 2.18.28 to upload the files in the Raster (miscellaneous) section as I used to do. I just get all the files not being recognised.
I have downloaded the latest QGIS 3.8, but do not understand this one at all.
Could someone help me with a step by step loading of the OS raster data into the QGIS system so that I can produce some maps please?
I also have the Geo referencing and sea tiles but again QGIS does not seem to like them. I am using EPSG:27700
Thank You
Derek
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220625/72ea9eab/attachment-0001.htm>
Message: 5
Date: Sat, 25 Jun 2022 09:59:12 -0600
Message-ID: <701c9b08-fd3f-a631-9cba-1434290a92d6 at stripfamily.net>
Content-Type: text/plain; charset="us-ascii"
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220625/45506ec4/attachment.htm>
Subject: Digest Footer
End of Qgis-user Digest, Vol 196, Issue 27
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220625/cc585921/attachment-0001.htm>
