[Qgis-user] geolocating a list of addresses
Thayer Young
thayeray at yahoo.com
Thu Mar 3 07:52:20 PST 2022
Hi Francesca,
As Ujaval has already pointed out, your problem is probably with the CRS of one of your layers. To check which one is the problem I recommend that you add a basemap, e.g. OpenStreetMap Standard, using the QuickMapServices plugin. The tutorials linked below will show you how to do that, if you do not know already.
https://docs.qgis.org/3.16/en/docs/training_manual/qgis_plugins/index.html
If the problem is with your CSV file, you should try opening it again, and check that you have set the x and y and CRS correctly. For lat lon data you probably want WGS 84 as the CRS (EPSG code 4326).
If your point coordinates are wonky, you can try the geocoding again using the "Batch Nominatim Geocoder" tool in newer versions of QGIS (3.20+). If your data are in the western hemisphere, check that the longitude is negative, if in the southern hemisphere latitude should be negative.
-Thayer
On Thursday, March 3, 2022, 08:09:34 AM EST, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote: Date: Thu, 3 Mar 2022 12:51:14 +0100
From: Francesca Parente <francescaparente.rse at gmail.com>
To: Ujaval Gandhi <ujaval at spatialthoughts.com>
Cc: QGIS User List <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] geolocating a list of addresses
Message-ID:
<CAA8dZSc1YZD4RS3apnvq7uubExXyZYeFVhwXm=Zy+3uG52JxoA at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Thanks a lot Ujaval, now I see the points displayed!
The problem is different than I though then, because it's like this new
layer has a different scale with respect to the ones I was already working
on... how can I reconcile the two, in order to see the points within the
boundaries of related polygons?
Thank you so much once again!
Francesca
Il giorno gio 3 mar 2022 alle ore 12:20 Ujaval Gandhi <
ujaval at spatialthoughts.com> ha scritto:
> Right-click the layer and select 'Zoom to Layer'. If you still do not see
> the points, it must be a problem with your CRS or the coordinates itself.
> (Make sure Longitude is X field and Latitude is Y field)
> [image: Logo] <https://spatialthoughts.com/>
> Ujaval Gandhi
> Spatial Thoughts
> mobile: +91-8095684687
> email: ujaval at spatialthoughts.com
> [image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
> Twitter icon] <https://twitter.com/spatialthoughts>
> On Thu, Mar 3, 2022 at 4:45 PM Francesca Parente <
> francescaparente.rse at gmail.com> wrote:
>> Hello everyone and thank you for making this mailing list available!
>> I am using QGIS 3.18 and I have a list of punctual street addresses
>> (along with their latitude/longitude data), that I would like to display
>> and analyze.
>> I've already set a project with polygon layers and related attributes, in
>> which the locations should fit.
>> I imported the addresses in this project as a delimited text layer
>> (specifying the coordinates info in the geometry definition menu), but
>> nothing happened next - other than seeing it added to the project layers'
>> list.
>> I'm not sure on how to proceed further and any advice you may have would
>> be so very much appreciated.
>> Many thanks for your time and good day to all!
>> Francesca Parente
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/0c76e47d/attachment-0001.html>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/633fba0f/attachment.html>
