[Qgis-user] Elevation Profiles
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Sun Mar  6 04:49:10 PST 2022
> *krishna Ayyala*
> /Sat Mar 5 22:06:54 PST 2022/
> Nicolas, I ran the Drape tool as shown below. It resulted in a new  line
> feature called "Draped" and added to my map. But this new feature has
> exactly same attributes as that of "Lines" feature. i.e. it does not have
> any new field such as Z added to the attribute table.
Hi krishna Ayyala,
please read the tool documentation at
https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#qgissetzfromraster
As written in the documentation, the "Drape" tool does not add a new
field with the Z coordinate value to the attribute table. It adds the Z
coordinate value to each vertex in each feature geometry of the vector
layer overlapping the raster layer.
In general, if you need to copy the Z coordinate value of the feature
geometry in a field of the attribute table, you can use the "Extract Z
values" tool with the layer containing the feature geometries with
vertices that have the Z coordinate value.
Anyway, consider that a line type feature geometry is made by more than
one vertex, and that the "Extract Z values" tool stores only one value
for each input feature, so if you want to store the Z coordinate value
for each vertex of each line type feature geometry in a field of the
attribute table, then you would probably need to first extract the
vertices of the line layer to a point layer and after that extract the Z
value of each point.
Alternatively you could use the field calculator to perform more complex
different calculation, or you could afterward perform other data
processing such as e.g. aggregate the Z values of the vertices of each
input line feature.
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220306/a482f78b/attachment-0001.html>
