[Qgis-user] Sorting attribute columns in 3.22
Pero Despotovic
pero at dejic.com
Mon Mar 14 10:27:52 PDT 2022
Indeed,
I have the same and have to re-apply the filter every now and then.
Beste Grüße
Pero
> On Mar 14, 2022, at 10:05, Uwe Fischer <gisfisch at t-online.de> wrote:
> Hello,
> thank you very much. After using this, I suddenly was able to sort by other columns like desired – but just for 2 or 3 times, after that it did not work any more. Very strange in fact.
> Regards, Uwe
> Von: Pero Despotovic [mailto:pero at dejic.com <mailto:pero at dejic.com>]
> Gesendet: Montag, 14. März 2022 17:21
> An: Totò Fiandaca <pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>>
> Cc: Uwe Fischer <gisfisch at t-online.de <mailto:gisfisch at t-online.de>>; qgis-user <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>>
> Betreff: Re: [Qgis-user] Sorting attribute columns in 3.22
> As a workaround, I am using a right click on the header in the attribute table
> and specify the field by which I'd like to sort.
> <image001.jpg>
>> On Mar 14, 2022, at 08:57, Totò Fiandaca via Qgis-user <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> wrote:
>> The problem is known,
>> has been fixed, you have to wait for the next update.
>> https://github.com/qgis/QGIS/pull/47749 <https://github.com/qgis/QGIS/pull/47749>
>> regards
>> Il giorno lun 14 mar 2022 alle ore 16:52 Uwe Fischer via Qgis-user <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> ha scritto:
>>> Hello List,
>>> sorting attribute columns does not work like before in 3.22. In the manual, it reads that you can sort by clicking the column header, but that has no effect in my case. What am I doing wrong? There is a small black sorting arrow on the almost left column, but I need to sort by other columns, too.
>>> Best regards and thanks , Uwe
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Ing. Salvatore Fiandaca
>> mobile.:+39 327.493.8955
>> m: pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>
>> C.F.: FNDSVT71E29Z103G
>> P.IVA: 06597870820
>> membro QGIS Italia - http://qgis.it/ <http://qgis.it/>
>> socio GFOSS.it - http://gfoss.it/ <http://gfoss.it/>
>> blog: https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/>
>> FB: Co-admin - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/> <https://www.facebook.com/qgis.it/>
>> TW: <http://goog_95411464/>https://twitter.com/totofiandaca <https://twitter.com/totofiandaca>
>> 43°51'0.54"N 10°34'27.62"E - EPSG:4326
>> “Se la conoscenza deve essere aperta a tutti,
>> perchè mai limitarne l’accesso?”
>> R. Stallman
>> Questo documento, allegati inclusi, contiene informazioni di proprietà di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario in relazione alle finalità per le quali è stato ricevuto. E' vietata qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di informare tempestivamente il mittente e distruggere la copia in proprio possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220314/799b8f21/attachment.html>
