[Qgis-user] Model Designer - GDAL - Vector Conversion
Johanna Botman
johannab at melton.vic.gov.au
Mon Mar 14 15:10:45 PDT 2022
Thank you for the follow up, Nicolas,
I’ll spend a little more time on learning to insert that ID column. I tried the Convert to Geopackage and then to TAB files, but that was not satisfactory. The ID column was still missing
Johanna Botman
Assets / GIS Officer – Melton City Council
From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Sent: Thursday, 10 March 2022 9:25 AM
To: Johanna Botman <johannab at melton.vic.gov.au>
Cc: Brent Wood <Brent.Wood at niwa.co.nz>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Model Designer - GDAL - Vector Conversion
You don't often get email from njacadieux.gitlab at gmail.com<mailto:njacadieux.gitlab at gmail.com>. Learn why this is important<http://aka.ms/LearnAboutSenderIdentification>
To my knowledge, the tab file does not need a FID column to work. I may be wrong but a geopackage must have a FID column. I am sure you could create that field afterwards in the model or create a geopackage and then a tab file.
Nicolas Cadieux
https://gitlab.com/njacadieux<https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.com%2Fnjacadieux&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Cae271fe7ceb24fff072908da021ba93c%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637824615822762561%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=9c4yD6%2BappZe3O6nztd2pReFpgLP4qjZNe5VWREHH3E%3D&reserved=0>
Le 8 mars 2022 à 18:54, Johanna Botman via Qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> a écrit :
Hi Brent,
I think that is the way that I have to go. I was hoping that it would be a good use of the Modeller
Johanna Botman
From: Brent Wood <Brent.Wood at niwa.co.nz<mailto:Brent.Wood at niwa.co.nz>>
Sent: Wednesday, 9 March 2022 10:50 AM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>; Johanna Botman <johannab at melton.vic.gov.au<mailto:johannab at melton.vic.gov.au>>
Subject: Re: Model Designer - GDAL - Vector Conversion
You don't often get email from brent.wood at niwa.co.nz<mailto:brent.wood at niwa.co.nz>. Learn why this is important<http://aka.ms/LearnAboutSenderIdentification>
Have you considered a script or batch file using ogr2ogr to do this for you?
Brent Wood
Principal Technician, Fisheries
NIWA
DDI: +64 (4) 3860529
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> on behalf of Johanna Botman via Qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Sent: Wednesday, March 9, 2022 12:41
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Subject: [Qgis-user] Model Designer - GDAL - Vector Conversion
I am trying to use the Model Designer to automate the creation of Tab files from SQL Database Tables.
I am using GDAL – Vector Conversion – Convert format
The resulting Tab file is missing the Primary Key field.
If use that same algorithm to export to a Geopackage, the PK is there.
I know that I can right click the SQL Table and select Export. That Tab file contains the PK. I need to export 30 tables so am looking for some automation.
Why does the algorithm produce a table without the key field?
Johanna Botman
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220314/e5789843/attachment.html>
