[Qgis-user] hide attribute from popup window
Stephen Sacks
ssacks456 at gmail.com
Mon Mar 21 06:58:57 PDT 2022
Sebastian -
Your advice is exactly what I needed. It works perfectly. THANK YOU.
There's one thing I would add for others who want the same advice:
the attribute form is found at the tab called "manage custom forms and
field editor configuration"
On 3/20/2022 9:18 PM, Sebastian Gutwein wrote:
> If you change it to hidden in the layer properties>attribute form>
> widget type you won't see it in the identify window or feature form
> window.
> The default is text.
> On Sun, Mar 20, 2022 at 8:18 PM Stephen Sacks via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
> I would like to limit which fields appear in the popup window when
> I click on a feature. In the layer's attribute table, I can Hide
> a field but it still appears in the popup window when I click a
> feature with the Identify tool.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220321/5b34fb04/attachment.html>
