[Qgis-user] creating vector layer from slope map with few classes
Shinoto, PD Dr. Maria
maria.shinoto at zaw.uni-heidelberg.de
Tue Mar 29 16:51:15 PDT 2022
Hi Kirk,
that was helpful, thank you.
I am not yet where I need to be, but so far I could create two classes with the formula found in the docs (https://docs.qgis.org/3.10/en/docs/user_manual/working_with_raster/raster_analysis.html) along this line:
`("slope at 1" < 50) * 1 + ("slope at 1" >= 50) * 2`
At this moment, my biggest problem is creating the vector file, the window claims that the file name is too long. This cannot be the case, and the directory itself should be OK. So now I am trying to get this done, and then I will test three classes, which I did not get working up to now either.
If there are easy answers to these two questions, I would be pleased, otherwise, I will try tomorrow.
Thanks a lot,
Maria
> Am 30.03.2022 um 07:14 schrieb kirk <kirk at nortekresources.com>:
> Hi Maria.
> The symbology does not reclassify the underlying raster, it just changes the way it is displayed. Use the raster calculator to generate a new raster with the Classes you require. The native qgis calculator works well. You can find it in the upper word menu under raster. Once you have your raster reclassified, you can then convert it to a vector format
> Kirk Schmidt
> Sent from my Galaxy
> -------- Original message --------
> From: "Shinoto, PD Dr. Maria via Qgis-user" <qgis-user at lists.osgeo.org>
> Date: 2022-03-29 6:32 p.m. (GMT-04:00)
> To: qgis forum <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] creating vector layer from slope map with few classes
> Hi,
> I have created a slope map from a DTM.
> I have limited the symbology to three meaningful classes and wish to create a vector layer with polygons of three classes from that. The conditions are One-Channel-Pseudocolor, Channel1 (Gray), interpolation discrete, modus "fortlaufend" -- not identical interval or quantile, 3 classes with values <=20, 20 - 40, > 40.
> The classes show up in the layer design panel symbology tab, but the layer browser still (thankfully!) shows the greyscale ramp.
> I wish to create a vector layer with polygons from the 3 classes.
> All solutions I have looked up work under slightly different condition. After all I do not know how to get the data of the DTM into three classes like "Flat-Gentle-Steep"; I think the vectorization should work easily then.
> Can anybody hint me to a solution?
> Thanks and best wishes,
> Maria
> Qgis-user mailing list
