[Qgis-user] creating vector layer from slope map with few classes
Shinoto, PD Dr. Maria maria.shinoto at zaw.uni-heidelberg.de
Wed Mar 30 17:57:43 PDT 2022
Hi Richard,
this was great, a big thanks to you as well. Classifying was the first problem, and thanks to your step by step explanation, it worked well, easy, quick, producing exactly the results I wished for.
Cheers to you and the community,
Maria
> Am 30.03.2022 um 20:36 schrieb Richard McDonnell <richard.mcdonnell at opw.ie>:
> Hi Maria,
> There is an option to reclassify a raster called Reclassify by Table, which should create the classified raster you are looking for.
> You can find the Reclassify by Table in the Processing Toolbox, you can then do the following.
> 1.      Select the Raster you want
> 2.      Under Reclassification table click on the button with the three dots.
> a.      You need to add a row for each class you want, by clicking Add Row
> b.      For each row set the Minimum and Maximum pixel Values and the new Value
> c.      Click OK once you are happy
> 3.      Set your output no data value, in your case it can be zero
> 4.      Set Range boundaries as you require
> 5.      Set your Output data type, I would, based on your description select Byte
> 6.      Set location to which you want to save your Raster.
> To polygonise the data then is just a simple matter of using the QGIS Polygonize tool, which again can be accessed from the Processing Toolbar. Its default settings should create the output you are looking for.
> Hope the above goes some way to helping you.
> Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> FRM Data Management
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> https://www.opw.ie
> Email Disclaimer: https://www.opw.ie/en/disclaimer/
>> -----Original Message-----
>> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Shinoto, PD
>> Dr. Maria via Qgis-user
>> Sent: 29 March 2022 22:25
>> To: qgis forum <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] creating vector layer from slope map with few classes
>> Hi,
>> I have created a slope map from a DTM.
>> I have limited the symbology to three meaningful classes and wish to create a
>> vector layer with polygons of three classes from that. The conditions are One-
>> Channel-Pseudocolor, Channel1 (Gray), interpolation discrete, modus
>> "fortlaufend" -- not identical interval or quantile, 3 classes with values <=20, 20 -
>> 40, > 40.
>> The classes show up in the layer design panel symbology tab, but the layer
>> browser still (thankfully!) shows the greyscale ramp.
>> I wish to create a vector layer with polygons from the 3 classes.
>> All solutions I have looked up work under slightly different condition. After all I
>> do not know how to get the data of the DTM into three classes like "Flat-Gentle-
>> Steep"; I think the vectorization should work easily then.
>> Can anybody hint me to a solution?
>> Thanks and best wishes,
>> Maria
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
