[Qgis-user] help with shortest-path/network analysis (multiple origins to multiple destinations)
Francesca Parente francescaparente.rse at gmail.com
Thu May 5 07:37:09 PDT 2022
Hello everyone,
I'd need to identify optimal destinations (within a point layer of
geolocated facilities) for each territory of a given set of possible
origins.
I already calculated a distance matrix between the two point-layers, and
also applied the distance-to-nearest-hub tool to generate a string layer
and identify the optimal facilities.
But I'd like to obtain a more realistic estimate, accounting for the roads
network (and ideally their travel times). With quite a few issues, I
finally managed to import an OSM road network from download.geofabrik.de
(in order to cover my area of interest, I had to merge two different
vectors fo Center and Southern Italy and then extract a focus spot in
between the two and save it as a lighter layer, otherwise it also took an
eternity to run every analysis).
So now my question would be: is there a tool to perform a layer-to-layer
shortest-path analysis that takes it into account?
All that I could find was either point-to-point or
layer-to-point/point-to-layer (I looked also at built-in network analysis
tool and Qneat3 plugin).
Any kind of inputs and suggestions will be more than welcome!
Thanks a lot for your support and have a good day,
Francesca
Francesca Parente
_ SESS Euro PhD
<https://phd.uniroma1.it/web/FRANCESCA-PARENTE_nT1602922_IT.aspx> in
SocioEconomic and Statistical Studies
_ Luiss SEP <https://sep.luiss.it/> School of European Political Economy
email: francescaparente.rse at gmail.com
       parentef at luiss.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220505/9b63aa2f/attachment.htm>
