[Qgis-user] Using Grass7 r.stream.order on QGIS 3.24
Rijyuta Kaabaadee
rijyutanayan at gmail.com
Thu May 12 00:21:11 PDT 2022
Thank you for responding.
We are writing a python plugin for QGIS. This plugin intends to use
r.stream.order to get previous and next stream segments for a stream
network.
It will be better if the r.stream.order can be used within QGIS.
Your suggestion is also worth considering and I am looking at
https://grasswiki.osgeo.org/wiki/GRASS_and_Python to explore further in
that direction.
Regards,
Rijyuta
On Thu, May 12, 2022 at 12:38 PM Micha Silver <tsvibar at gmail.com> wrote:
> I think that the processing toolbox does not automatically create a new
> algorithm for GRASS modules added to GRASS.
> May I ask why not to run r.stream.order from GRASS directly?
> On 5/11/22 13:37, Rijyuta Kaabaadee via Qgis-user wrote:
> Hello QGIS community,
> I have recently started using QGIS. I am using QGIS 3.24 on Ubuntu 20.04.
> I want to use the r.stream.order tool from the grass7 provider in the QGIS
> processing toolbox. However this tool is not visible in the toolbox. So I
> followed the documentation:
> https://docs.qgis.org/3.22/en/docs/training_manual/grass/grass_setup.html
> to get a working grass7 shell. From this shell I was able to install
> r.stream.order using g.extension. It was installed successfully in
> ~/.grass7/addons/bin/r.stream.order. Even after restarting the QGIS
> application, r.stream.order is not visible in the processing toolbox.
> Has anyone faced a similar issue before?
> Regards,
> Rijyuta
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918https://orcid.org/0000-0002-1128-1325
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220512/553c2f28/attachment-0001.htm>
