[Qgis-user] Problem merging 30-m SRTM tiles in QGIS 3.24.3 for MacOS 10.14.6
Walter Alvarez
platetec at berkeley.edu
Fri May 20 11:38:30 PDT 2022
Thank you, Thayer! That indeed was part of the problem, but I believe another problem was that the files were saved in iCloud. When I took them out of iCloud and looked for the hidden Tools window, the DEMs merged properly! I greatly appreciate your help!
Walter
> On May 20, 2022, at 6:01 AM, Thayer Young <thayeray at yahoo.com> wrote:
> Hi Walter,
> Sometimes after entering parameters the tool window drops behind the main QGIS window. Try either moving the QGIS window out of the way or right click the QGIS icon in the Dock and select "Show All Windows" and see if you can find it again. Hope this helps.
> -Thayer
> On Friday, May 20, 2022, 06:35:24 AM EDT, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
> Date: Thu, 19 May 2022 14:30:39 -0700
> From: Walter Alvarez <platetec at berkeley.edu <mailto:platetec at berkeley.edu>>
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Problem merging 30-m SRTM tiles in QGIS 3.24.3
> for MacOS 10.14.6
> Message-ID: <1855F019-F0CC-4329-9CAA-6667A862B344 at berkeley.edu <mailto:1855F019-F0CC-4329-9CAA-6667A862B344 at berkeley.edu>>
> Content-Type: text/plain; charset="utf-8"
> I?m trying to merge either two or twelve 30-m SRTM tiles using QGIS 3.14.3. In either case (2 or 12) I am stopped by the following problem:
> Using Raster > Miscellaneous > Merge?
> I get the ?Merge" window. I try to use Input layers > Elements selected > ??"
> That takes me to the "Multiple Selection" window, showing the 2 or 12 files I want to merge (filenames: nXXeXXX_1arc_v3 [EPSG:4326]).
> After selecting all the files, when I click ?OK? the "Multiple Selection Window? and the ?Merge? window both disappear, and I cannot figure out what to do next, or do differently.
> I can?t figure out how to get past this problem and merge my tiles.
> Thanks for any help you can offer!
> Walter
> __________
> Walter Alvarez
> Professor of the Graduate School
> Department of Earth and Planetary Science
> University of California Berkeley
__________
Walter Alvarez
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220520/5ba0acaa/attachment.htm>
