[Qgis-user] Identify tool and closest vertices (z-values)
Andreas Neumann
a.neumann at carto.net
Tue May 24 03:22:02 PDT 2022
Hi Karl-Magnus,
Thank you for your confirmation.
It must be something weird about 3D detection from QGIS for Postgis
layers. I tested with other 3D layers and they work fine, but the layer
that fails to work with Z-Values is from a much older Postgis-DB.
Maybe it would work fine if we transfer the data to a more modern
Postgis-DB ...
QGIS display the Metadata as Polygon (PolygonZ) though ...
Strange ...
Andreas
On 2022-05-24 11:21, Karl Magnus Jönsson wrote:
> Hi!
> It seems to work for me in 3.22.5 with Postgis PolygonZ. Can't remember
> that I've done any custom settings for that.
> Karl-Magnus Jönsson
> Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> För Andreas Neumann
> via Qgis-user
> Skickat: den 24 maj 2022 10:53
> Till: QGIS User List <Qgis-user at lists.osgeo.org>
> Ämne: [Qgis-user] Identify tool and closest vertices (z-values)
> Hi,
> We have a a Postgis PolygonZ data set an want to query the third
> dimension of the closest vertex. According to my users, this used to
> work fine in older QGIS versions, but now we can only see the x/y
> values and not z-values anymore.
> I just tested it on QGIS 3.22 (LTR) and can conform that the z-values
> are not displayed in the derived data of the identify tool.
> Is there any hidden setting that helps us to display the z-values again
> - or a connection parameter that forces QGIS to treat it correctly as a
> 3d data set?
> Thank you for any hints,
> Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220524/2a561e05/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220524/2a561e05/attachment-0001.png>
