[Qgis-user] query for Virtual Layer in relation to another layer
Uwe Fischer
gisfisch at t-online.de
Fri Nov 4 06:18:44 PDT 2022
Moin moin,
that's exactly the information I was looking for. Thanks again and sunny weekend,
Uwe
-----Ursprüngliche Nachricht-----
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Jürgen E. Fischer via Qgis-user
Gesendet: Freitag, 4. November 2022 14:12
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] query for Virtual Layer in relation to another layer
Moin Uwe,
On Fri, 04. Nov 2022 at 13:59:35 +0100, Uwe Fischer wrote:
> great - it works as expected!! Thank you!
> How can I find out about the engine that is used and the SQL syntax
> for virtual layers? I'd like to learn about it to be able to build
> more queries like this one.
Well, || is the standard syntax, but there are probably also databases that will take + to concatenate strings too. It's SQLite:
https://docs.qgis.org/3.28/en/docs/user_manual/managing_data_source/create_layers.html#supported-query-language
14.2.5.2. Supported query language
The underlying engine uses SQLite and SpatiaLite to operate.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
