[Qgis-user] multiple csv file import
Hugh Kelley
hghklly at gmail.com
Tue Nov 15 11:58:26 PST 2022
David, this was my first thought when i saw this question as well.
however, I didn't look for very long but I haven't seen a way to tell
ogr2ogr to read columns in a csv as the lat/lon and write those as points
to the shapefile. I generally write a csv to postgres as a non-spatial
table and then process the lat lon columns with postgis.
Are there arguments for ogr2ogr that can do this?
On Tue, Nov 15, 2022 at 12:30 PM David Strip via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> You might consider ogr2ogr as an alternative approach. You can run this
> from the command line allowing you to use shell scripts to iterate through
> all your .csv files. There are also python bindings for ogr2ogr if you're
> more comfortable with python than shell scripts.
> On 11/15/2022 9:59 AM, Salvatore Mellino via Qgis-user wrote:
> Hello,
> thank you for your answer. I have many csv (about 100), so I need an
> automatic procedure. Maybe a python script...
> Il 15/11/2022 16:55, Nicolas Cadieux ha scritto:
> Hi,
> Yes, you can do that very easily using QGIS. Layer/add layer/add
> delimited text layer. Then just export the layer in the format of your
> choice. You may need to convert the coordinates in decimal degrees (ex 75
> 05 30.4 -> 75.0917777777778000000 ).
> You can do this in Excel using =(A6)+(B6/60)+(C6/3600)+(D6/3600) A= Deg,
> B= Min, C=Sec, D= Decimal Sec. Then export to csv.
> Nicolas
> On 2022-11-15 10:08 a.m., Salvatore Mellino via Qgis-user wrote:
> Hello,
> I would like to know if it is possible to import multiple csv files
> contained in a folder and to convert them in shapefiles (1 for each csv).
> All csv files are structured as "lat long value" separate by space and
> without any header line.
> Thank you for your help! Regards,
> Salvatore
> Qgis-user mailing list
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221115/c79360c9/attachment-0001.htm>
