[Qgis-user] Export to SQL Server plugin
    Pedro Venâncio
    pedrongvenancio at gmail.com
    Wed Nov 30 08:27:04 PST 2022
Hi Rikesh,
As Andrea said, you need to installgdal-mssandmsodbcsqlfrom OSGeo4W (
https://github.com/PedroVenancio/export_to_sql_server/issues/2#issuecomment-1240675079)
or any other way, if you have used the standalone installer.
Best regards,
Pedro
Andrea Giudiceandrea via Qgis-user <qgis-user at lists.osgeo.org> escreveu no
dia quarta, 30/11/2022 à(s) 15:18:
> *Rikesh Lad*
> *Wed Nov 30 04:12:40 PST 2022*
> GDAL command output:
> ERROR 1: Unable to find driver `MSSQLSpatial'.
> Hi Rikesh,
> it seems the error is quite self-explanatory: the MSSQLSpatial driver for
> the GDAL/OGR library is missing.
> I suppose you are using QGIS on Windows installed via OSGeo4W (the
> "standalone" or the "network" installer).
> Please open the OSGeo4W Shell and execute the command: ogrinfo --formats
> That command will list all supported vector format: very likely
> MSSQLSpatial is not among them. Such GDAL/OGR driver is not installed by
> default on Windows / OSGeo4W.
> In this case I think that installing the MSSQLSpatial GDAL/OGR driver
> using the OSGeo4W Setup program will fix the issue. This task could be a
> little bit difficult if you have installed QGIS using the standalone
> installer.
> Best regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221130/3657df51/attachment.htm>
