[Qgis-user] mdal / mesh simple formats
    Matt Boyd
    mattslists at gmail.com
    Fri Sep  2 20:44:03 PDT 2022
Hi Peter,
woohoo, awesome, okay now I get it and it works.
I thought that as the 2dm file had duplicates of the cells & nodes in
the simple mesh I was looking at that it wasn't needed. Also the xdmf
loads directly into paraview so I thought that QGIS would do the same
thing.
All I need to do is generate a 2dm file with nodes and cells like the
examples and my meshes *should work, easy.
Thanks again, I'll post this back to QGIS users in case anyone else
hits the same issue.
Matt
On Fri, Sep 2, 2022 at 5:58 PM Peter Petrik
<peter.petrik at lutraconsulting.co.uk> wrote:
> Hi,
> 1)
> on linux/docker, try to set
> export LD_LIBRARY_PATH=<path_to_folder_with_libmdal.so>
> ./mdalinfo ...
> 2) XDMF is a dataset with values ONLY. So in that menu you need to load 2dm file == definition of your mesh frame, and once loaded, you right-click on the mesh layer and "add values/datasets" in the properties (XMDF) file. Some files (e.g. netcdf) has it in one file all, but this one is different.  Best to check some online tutorials.
> Kind Regards,
> Peter Petrík
> CPO of Mergin Maps
> LI, Mergin Maps
