[Qgis-user] Polygon next to road search term
Jon
jonr at destar.net
Tue Sep 13 21:19:20 PDT 2022
I would want the polygon to have road access. So you should be able to
access the polygon firectly from a road. Just a corner touching may
work but that would depend on an easement and I am having enough
trouble just trying to figure out what I should be searching on without
throwing that in as well.
So at this point, the polygon should be able to be accessed by the road
line. So possibly 20' of the road line is touching the polygon.
-----Original Message-----
To: jonr at destar.net, Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Polygon next to road search term
Date: Tue, 13 Sep 2022 21:12:01 -0600
Is a polygon "next to a road" because one (or more) edges of the polygon is exactly coincident with the road line? Or is it within some distance of the road line? These lead to different solutions, but unless your data is very precise, asking for the boundary to be exactly coincident with a road line is not going to be very robust.Does your road polyline feature have a road width? If so, does that factor into "next to"?
On 9/13/2022 5:26 PM, Jon via Qgis-user wrote:
> I am trying to figure out if a property that is a polygon is next to a
> polyline (road). I am not well versed with QGIS and every search I do
> seems to tell me how to map a polygon onto a road or convert polylines
> to a polygon. I am not sure what exactly I need to search on to find
> some documentation on how to do what I am looking to do.
> What should I be searching on to find if a property that has 4 sides
> and is a polygon is next to a road? Is what I am trying to find called
> something specific and that is why I am not finding?
> Thanks for any help,
> Jon
> Qgis-user mailing list
