[Qgis-user] DXF Export symbolLayer
Simon Gröchenig
groechenig at zt-gis.at
Mon Jun 12 00:08:09 PDT 2023
Hi Richard,
thank you for your support.
I have added a (virtual) attribute 'RefName' with a similar CASE WHEN statement. But I don't see how this should change the DXF-output.
Some information:
* I have a point layer that I want to export to a DXF-file using the native:dxfexport algorithm.
* This layer has a categorized renderer.
* For the DXF export, I also set a field ("sgg_code" is my case) to split the features into several DXF-layers.
* Now I also have a field "RefName".
* The RefName corresponds with the expression used for the categorized rendering.
* And the RefName does NOT match the field "sgg_code" used for the DXF-split.
* I want to use the RefName (or labels set in categorized renderer) values instead of symbolLayer0, symbolLayer1, ...
I have attached a simple project with the point layer.
Simon
Von: Richard McDonnell <richard.mcdonnell at opw.ie>
Gesendet: Freitag, 9. Juni 2023 15:18
An: Simon Gröchenig <groechenig at zt-gis.at>
Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Betreff: RE: DXF Export symbolLayer
Hi Simon,
You don’t mention the field name in QGIS, but in the example below, I will use “TEST”
Create a new field, giving it a name, it can be “RefName” if you like, you can then create an expression like
CASE WHEN " TEST " ='symbolLayer0' THEN 'SomeOtherStringA'
WHEN " TEST " ='symbolLayer1' THEN 'SomeOtherStringB'
END
This should look at the “TEST” Attribute and where it has ‘symbolLayer0’ it will output 'SomeOtherStringA' and where “TEST” is ‘symbolLayer1’ it will output 'SomeOtherStringB'
When its complete you can delete any attributes you don’t need
I hope that helps,
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Simon Gröchenig via QGIS-User
Sent: 09 June 2023 10:12
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] DXF Export symbolLayer
Hi all,
I am trying to configure a DXF export using the native:dxfexport algorithm and layer symbology.
Using the categorized rendering for a vector layer results in values "symbolLayer0", "symbolLayer1", ... in the dxf-file. In Autodesk Viewer these values are the "Name", ArcMap imports these as "RefName" attribute.
My question: how can I modify the values symbolLayer0, symbolLayer1, ... to another string? A third-party tool requires special values here.
Best regards
Simon
Vermessungskanzlei Neumayr
Simon Gröchenig - Geoinformation
[cid:image001.jpg at 01D99ADA.4ADA9F90]
Albin Egger-Str. 10
9900 Lienz
Tel: +43 4852-68568-31
Email: groechenig at zt-gis.at<mailto:groechenig at zt-gis.at>
Web: http://www.zt-gis.at/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230612/8b113029/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230612/8b113029/attachment-0001.jpg>
Type: application/x-zip-compressed
Desc: dxf-export.zip
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230612/8b113029/attachment-0001.bin>
More information about the QGIS-User
