[Qgis-user] Running QGis on a machine with Python 3.11 and PyCharm ?
DelazJ
delazj at gmail.com
Mon Jun 12 05:57:38 PDT 2023
Le lun. 12 juin 2023 à 10:58, Johannes Kröger (WhereGroup) via QGIS-User <
qgis-user at lists.osgeo.org> a écrit :
> Hi,
[snip]
> The internet is full of ancient, random and poorly compiled batch scripts
> which really shouldn't be used anymore.
Great point! This is where IMHO QGIS official documentation should have a
say and play an authoritative role, with up to date, clear and meaningful
instructions.
This topic of configuring QGIS with python environment is to some extent
"discussed" at [0] and [1]. Do these pages meet the conditions to play that
authoritative role? I'm not that sure, given how recurring the topic
arises, but TBH I'm not versed enough in Python to be fully credible.
[0]
https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/ide_debugging.html#debugging-with-pycharm-on-ubuntu-with-a-compiled-qgis
[1]
https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/intro.html#python-applications
Regards,
Harrissou
> Cheers, Hannes
> Am 09.06.23 um 18:11 schrieb Toussaint OTTAVI via QGIS-User:
> Hi,
> I'm new to QGis. I'm trying to install latest version (3.28.7 LTR) on my
> machine. It does not run. The startup window shows during a few seconds,
> then, nothing.
> I tried several older versions. None of them wants to start. The exception
> is 3.14, which starts, and works perfectly.
> On my machine, I already have a Python 3 installed (currently, 3.11.1), on
> absolute path C:\Python, PYTHONPATH system variable pointing to it, and
> system path, too. I also have PyCharm installed. I think this may be the
> cause of my problem. I noticed the included interpreter (C:\Program
> Files\QGIS 3.28.7\bin\python.exe) does not start at all, with Python error :
> File "C:\Python\Lib\io.py", line 54, in <module>
> ImportError: cannot import name 'text_encoding' from 'io' (unknown
> location)
> If I understand well, I'll have to write a customized startup script, with
> correct path (not pointing to my c:\python\lib) so that QGis can start
> using the included Python interpreter (and not my system-wide one). But I
> didn't find how to achieve that.
> Later, I think I'll have to write some QGis Python code. Then, I'll need
> to run it in "developer" mode : being able to put the source code in a git
> repository, edit the code in PyCharm, and run it. Any clues are welcome.
> Thank you in advance. Kind regards
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> Johannes Kröger / GIS-Entwickler/-Berater
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230612/1296f724/attachment.htm>
More information about the QGIS-User
