[Qgis-user] painful file-browser
Hugh Kelley
hghklly at gmail.com
Mon Mar 6 07:10:01 PST 2023
Thomas, not the solution you are looking for most likely but I rarely use
the qgis file navigator.
Generally I can either drag files in from windows file explorer directly or
paste in a file path, replacing \ with / as needed. Shift - right click
will allow you to copy the path of a file.
The one exception to this I run into occasionally is renaming a layer in a
gpkg, in that case I still navigate to the gpkg in the browser and rename
there, but maybe someone has a workaround for that too.
Best, hugh
On Mon, Mar 6, 2023, 9:33 AM Thomas Struller via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hallo,
> sorry that I start again this issue, but working with the file-browser in
> qgis 3.28.4 ltr or 3.30 is very, very slow and painful. In fact working
> with qgis is not possible.
> My installation:
> Win 11 pro on think pad AMD Ryzen 7 PRO 4750U with Radeon Graphics 1.70
> GHz, 32 GB
> Connected network drives on window-server 2016
> What I did:
> New profile -> no result, the same painful „speed“ in qgis filebrowser
> Disable of esri file gdb driver -> no result
> Hide of not nessecary network drives -> no result
> Are there some hints out there to bring qgis to a „normal“ work speed with
> ist file-browser?
> Freundliche Grüße
> Thomas Struller
> Diplom Geologe BDG, V18
> *akademischer Geoinformatiker*
> *Sachverständiger nach BBodSchG §18*
> *SG1 historische Recherche SG2 Pfad Boden-Grundwasser*
> *privater Sachverständiger der Wasserwirtschaft*
> T +49 911 12076-111
> M +49 170 3320494
> thomas.struller at LGA-geo.de
> LGA Institut für Umweltgeologie und Altlasten GmbH
> Christian-Hessel-Straße 1 | 90427 Nürnberg
> Geschäftsführung: Carlo Schillinger | Dr. Jürgen Kisskalt
> Gesellschaftssitz: Nürnberg | Registergericht Nürnberg HRB 18895
> info at LGA-geo.de | LGA-geo.de <https://www.lga-geo.de/> | Datenschutz
> <https://www.lga-geo.de/datenschutz/>
> Wir sind auf dem Weg zu einem papierfreien Büro.
> Berichte, Rechnungen und weitere Dokumente empfangen und
> versenden wir bevorzugt elektronisch per E-Mail.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230306/49cff971/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230306/49cff971/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230306/49cff971/attachment-0003.jpg>
More information about the QGIS-User
