[Qgis-user] File Geodatabase raster datasets readable in GDAL 3.7.0 (was Re: Unable to open some LISTdata open data ESRI File Geodatabases)
Even Rouault even.rouault at spatialys.com
Thu Mar 9 08:13:54 PST 2023
Just to inform you that GDAL 3.7.0 will include a driver to read
directly File Geodatabase raster datasets:
https://github.com/OSGeo/gdal/pull/7389 . I've successfully tested it
against the below datasets, among others.
They will consequently be directly be usable by QGIS once QGIS is built
against this GDAL version (whose release will be in May)
Even
Le 16/12/2022 à 00:36, Nyall Dawson a écrit :
> On Fri, 16 Dec 2022 at 09:18, Even Rouault via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>> Hi Peter,
>> yes I confirm this dataset is a raster gdb. I can sort-of open it with
>> my QGIS + GDAL master build using the OpenFileGDB driver, but you'll see
>> the raster tables in a raw unusable way. For example layers like
>> fras_blk_NCH_ES_WATER_LOGGING_HAZARD which contains the tiles as
>> compressed data in a BLOB column.
>> You could try the https://github.com/r-barnes/ArcRasterRescue utility to
>> convert into GeoTIFF
> FWIW, I've had more luck with the fork at
> https://github.com/justinfisk/ArcRasterRescue
> Nyall
>> You could also kindly or not kindly suggest your administration to not
>> use proprietary formats for open data whereas thereare so many open
>> alternatives, like GeoTIFF...
>> Small "advertizing": for those interesting, there's a funding
>> opportunity to develop a GDAL open source raster driver to be able to
>> read filegdb rasters that QGIS could use to open directly such files.
>> Contact me off-list if interested.
>> Even
>> Le 15/12/2022 à 23:49, JOLLY, Peter via QGIS-User a écrit :
>>> Hello
>>> I've downloaded some  datasets from the LISTdata open data repository (https://listdata.thelist.tas.gov.au/opendata/index.html) -  which is a great service.
>>> However, I can't open any datasets that are solely an ESRI File Geodatabase, e.g. https://listdata.thelist.tas.gov.au/opendata/data/NCH_ES_WATER_LOGGING_HAZARD_STATEWIDE.zip (279 MB)
>>> Maybe these are raster gdb datasets? How can I tell if that is the case?
>>> Is there any way the open a raster gdb other than with ESRI software?
>>> I can open gdb files in QGIS from LISTdata that are included as part of a set with shapefile and MapInfo tab files (e.g. in the "Tasmanian Irrigation Irrigation District" dataset). I'm guessing that is because these are vector gdb files?
>>> I'm running QGIS 3.10.6 ltr on Windows 10 64-bit (yes I know it's not the latest ltr, but it was the most recent "portable" build I have been able to find and run successfully).
>>> Thanks
>>> Peter
>>> Tasmania, Australia
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> http://www.spatialys.com
>> My software is free, but my time generally not.
More information about the QGIS-User mailing list
