[Qgis-user] Adding the Ubuntu Repo in Linux Mint
Richard Greenwood
richard.greenwood at gmail.com
Wed Mar 15 07:24:11 PDT 2023
I'm guessing that you are on version 21.x of Linux Mint. (You can check
your version at the command line by entering *cat /etc/issue*). At the
command line you can check that the Ubuntu QGIS repository is installed by
entering:
*cat /etc/apt/sources.list.d/qgis.list*
if you get the following two lines then you're good to go.
deb [arch=amd64] https://qgis.org/ubuntu jammy main
deb-src [arch=amd64] https://qgis.org/ubuntu jammy main
Alternatively, you can check by using the GUI "Software Sources" >
"Additional Repositories" where you should see:
[image: image.png]
On Wed, Mar 15, 2023 at 6:04 AM Steve via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> I have thoroughly confused myself with this, hopefully someone can help.
> Following the instructions here:
> https://www.qgis.org/en/site/forusers/alldownloads.html#
> I did manage to install QGIS 3.30, but judging by the GUI software sources
> app in Mint, I have not added the repo, so I am concerned about receiving
> future updates.
> In the box under Ubuntu instructions, the components are there (such as
> URI and distro codename) but no word on how to order them or what commands
> to use to apply them.
> Should a user at my level perhaps uninstall the deb package and just
> download the flatpak version?
> Thank you!
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/eeeb0c7f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/eeeb0c7f/attachment-0001.png>
More information about the QGIS-User
