[Qgis-user] Export n Shapefiles to GDB file
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Sat Mar 18 14:38:32 PDT 2023
I don’t work much with Geodatabase files but you can save multiple Shapefiles to a geopackage specifying the layer names for each input Shapefiles (I would try that first with the GDB file). Then, you could convert the geopackage to Geodatabase.
Nicolas
Envoyé de mon iPad
> Le 16 mars 2023 à 13:32, Gonzalo Lesperguer via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
> Hi to all, is it possible to export multiple shapefiles to a GDB file, I have tried but the result is only one shapefile.
> BR
> Gonzalo
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
