[Qgis-user] Cannot find Print Layout
Delaz J
delazj at gmail.com
Mon Mar 20 13:57:06 PDT 2023
Hi Mike,
Just in the case you would not be joking about icons size being too
small, note that you can adjust their size from within the Options
dialog
(https://docs.qgis.org/3.28/en/docs/user_manual/introduction/qgis_configuration.html#general-settings)
Regards,
Harrissou
Le 20/03/2023 à 21:13, ERT - Mike Breiding a écrit :
> On 3/20/2023 12:14 PM, Harrissou s. wrote:
>> Hi,
>> Here the HTML version
>> (https://docs.qgis.org/3.28/en/docs/user_manual/print_composer/overview_composer.html)
>> and "File" menu should instead be "Project".
> Thanks. I will bookmark that.
>> About missing icon, well... Maybe you don't have the " Project"
>> toolbar enabled (can be done from View menu --> Toolbars)
> I found it. The icons area a bit small for my eyes.
> Thanks,
> WV-Mike
>> Regards,
>> Harrissou
>> Le 20 mars 2023 19:45:25 GMT+01:00, ERT - Mike Breiding via QGIS-User
>> <qgis-user at lists.osgeo.org> a écrit :
>> Greetings,
>> I cannot see how to create a Print Layout.
>> I found the info below but I do not see a "New Print Layout icon"
>> or a "File" menu.
>> Obviously I am missing something.
>> WV-Mike
>> Ver. 3.28.4
>> Win 11
>> Before you start to work with the print layout, you need to load
>> some raster or vector layers in the QGIS map canvas
>> and adapt their properties to suit your own convenience. After
>> everything is rendered and symbolized to your liking,
>> click the New Print Layout icon in the toolbar or choose File ►
>> New Print Layout. You will be prompted to choose a
>> title for the new layout.
>> QGIS-3.28-DesktopUserGuide-en.pdf
>> <https://docs.qgis.org/3.28/pdf/en/QGIS-3.28-DesktopUserGuide-en.pdf>
>> Page 647
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230320/4071e34a/attachment.htm>
More information about the QGIS-User
