[Qgis-user] Adding road symbols to a map
ERT - Mike Breiding
epicroadtrips at gmail.com
Wed Mar 22 13:18:21 PDT 2023
Thanks, Thayer.
I will give it a try.
I thought there might be a labeling plug-in which would simplify there
process.
WV-Mike
On 3/22/2023 12:32 PM, Thayer Young via QGIS-User wrote:
> Hi Mike,
> Download an SVG (scalable vector graphic file) of each shield from
> Wikipedia and then set in the Labels tab of the Layer Styling panel
> set the text to your road's name as you like, then in the Background
> subtab (looks like a US interstate shield) check "Draw background",
> set shape to SVG and click on the ellipsis (...) and navigate to your
> shield's SVG file. Then you need to adjust the offset, shield size and
> the text size and color, etc.. It takes a while but when you figure it
> out be sure to save the style to an SLD or QML file so you can reuse
> it. If you are using PostGIS or other database you can save the style
> in the database as a default for your highway lines.
> -Thayer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230322/a343d787/attachment.htm>
More information about the QGIS-User
