[Qgis-user] DataPlotly plugin (ubuntu) : ModuleNotFoundError: No module named 'pandas
celati Laurent
laurent.celati at gmail.com
Fri Nov 3 06:55:47 PDT 2023
Good afternoon,
I work with Qgis 3.34.0-Prizren on Ubuntu.
I would like test and use the DataPlotly plugin.
I succeed in installing this plugin via the qgis plugin manager. But when i
try to enable it still into the plugin manager, i have an error message
saying :
In advance, thanks so much for your help.
Below i paste the whole message
Impossible de charger l'extension 'DataPlotly' provoque une erreur lors de
l'appel à sa méthode classFactory()
**ModuleNotFoundError: No module named 'pandas'**
File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in
_startPlugin
plugins[packageName] = package.classFactory(iface)
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/__init__.py",
line 33, in classFactory
from .data_plotly import DataPlotly
File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/data_plotly.py",
line 36, in
from DataPlotly.processing.dataplotly_provider import DataPlotlyProvider
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/processing/dataplotly_provider.py",
line 24, in
from DataPlotly.processing.dataplotly_scatterplot import
DataPlotlyProcessingScatterPlot
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/processing/dataplotly_scatterplot.py",
line 43, in
import pandas as pd
Version de Python : 3.10.12 (main, Jun 11 2023, 05:26:28) [GCC 11.4.0]
Version de QGIS : 3.34.0-Prizren Prizren, ffbdd678812
Chemin Python :
/usr/share/qgis/python
/usr/share/qgis/python/plugins
/usr/lib/python310.zip
/usr/lib/python3.10
/usr/lib/python3.10/lib-dynload
/usr/local/lib/python3.10/dist-packages
/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/HCMGIS/forms
/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/SentinelHub/external/requests_oauthlib-1.3.1-py2.py3-none-any.whl
/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview
/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/ca00fc0d/attachment.htm>
More information about the QGIS-User
