[Qgis-user] Opening the Data Source Manager crashes QGIS
Rob Dingen
rob.dingen at gmail.com
Thu Nov 9 03:18:34 PST 2023
Yes, the moment I click the data source manager icon it crashes without failure..
Thanks very much for your advice. I will follow the steps and see where I land.
Thanks
Rob
> On 9 Nov 2023, at 12:00 PM, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> Hi Rob,
> IF it is indeed a google earth plugin, which is causing the crash, reinstalling will not help because plugins are installed in your (QGIS)-profile, not in your installation.
> Is it constantly crashing?
> So either remove the plugin (via the plugin manager), or go into your profile (Settings/User Profiles) and remove the plugin by hand.
> A last option is to create a fresh profile, which will give you a profile without any plugin.
> See https://docs.qgis.org/3.28/en/docs/user_manual/introduction/qgis_configuration.html#working-with-user-profiles
> Hope This Helps :-)
> On 11/9/23 11:47, Rob Dingen via QGIS-User wrote:
>> Dear Forum,
>> Forgive my ignorance and infancy level using QGIS
>> Installed on IOS:
>> QGIS version3.32.3-Lima
>> Qt version5.15.2
>> Python version3.9.5
>> When I try to open the Data Source Manager the application crashes. I probably did something wrong with a google earth plugin.
>> Removing and installing a new copy does not help
>> Could anyone advise how to install a clean version without importing the files which cause the crash?
>> Please keep in mind I am a novel user .. not a developer
>> Grateful!
>> Best
>> Rob
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User
