[Qgis-user] Installing gdal-mrsid with osgeo4w-setup.exe command fails
Richard McDonnell
richard.mcdonnell at opw.ie
Tue Apr 2 03:42:52 PDT 2024
Hi Simon,
Not an IT person, but there are a number of formats, supported by gdal which don't, by default install. This is due to them requiring a separate licencing agreement.
You will need to manually install these, in the setup app, by using the Advanced install and under Select Packages, Libs select dgal-mrsid.
You can use the Search to help find it and other formats like ECW (gdal-ecw).
Hope that helps,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Simon Gröchenig via QGIS-User
Sent: 29 March 2024 07:10
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Installing gdal-mrsid with osgeo4w-setup.exe command fails
Hi all,
a customer installs qgis with the following command at Baramundi.
path/to/osgeo4w-setup.exe<https://outlook.office.com/local/path/file:/kint01.ki.tal-oil.com/APPS/QGIS/_Deployment/osgeo4w-setup.exe> -q -A -L -l \\<https://outlook.office.com/local/path/file:/kint01.ki.tal-oil.com/apps/qgis/_Deployment/Repo/>url.com\apps\qgis\_Deployment\Repo\<https://outlook.office.com/local/path/file:/kint01.ki.tal-oil.com/apps/qgis/_Deployment/Repo/> -a x86_64 -g -k -P qgis gdal-mrsid -o -k
While QGIS is installed fine, gdal-mrsid is silently failing (cannot load sid-files in QGIS). The problem occurs since upgrading to QGIS 3.36.
The installation works using the setup.exe graphical app.
Any ideas?
Best regards
Simon
_______________________________
Vermessungskanzlei Neumayr
Simon Gröchenig - Geoinformation
[cid:image001.jpg at 01DA84F2.E484C730]
Albin Egger-Str. 10
9900 Lienz
Tel: +43 4852 68568 31
Mobil: +43 664 1544804
Email: groechenig at zt-gis.at<mailto:groechenig at zt-gis.at>
Web: http://www.zt-gis.at/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240402/98930f79/attachment.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240402/98930f79/attachment.jpg>
More information about the QGIS-User
