[Qgis-user] Installing gdal-mrsid with osgeo4w-setup.exe command fails
    Simon Gröchenig
    groechenig at zt-gis.at
    Tue Apr  2 21:54:06 PDT 2024
Hi Andrea,
thanks for pointing me to the osgeo4w-dev list.
Best regards,
Simon
Von: Andrea Giudiceandrea <andreaerdna at libero.it>
Gesendet: Dienstag, 2. April 2024 20:13
An: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Cc: Simon Gröchenig <groechenig at zt-gis.at>
Betreff: Re: [Qgis-user] Installing gdal-mrsid with osgeo4w-setup.exe command fails
> Richard McDonnell richard.mcdonnell at opw.ie
> Tue Apr 2 03:42:52 PDT 2024
> You will need to manually install these, in the setup app, by using the Advanced install and under Select Packages, Libs select dgal-mrsid.
Hi Richard,
it looks like the issue occurs using the command line installation,
while it doesn't occur using the installer GUI.
> Simon Gröchenig groechenig at zt-gis.at
> Fri Mar 29 00:09:33 PDT 2024
> While QGIS is installed fine, gdal-mrsid is silently failing (cannot load sid-files in QGIS). The problem occurs since upgrading to QGIS 3.36.
Hi Simon,
I suggest you to ask to the osgeo4w-dev mailing list
https://lists.osgeo.org/mailman/listinfo/osgeo4w-dev or to file a ticket
to https://trac.osgeo.org/osgeo4w/
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240403/47d4f0b0/attachment.htm>
More information about the QGIS-User
