[Qgis-user] Moving many project files - bulk updating paths to tables?
oisin.kelly.wild at gmail.com oisin.kelly.wild at gmail.com
Thu Apr 4 11:55:24 PDT 2024
If you use Python it should be fairly simple to enumerate all layers, test to see if they're file based and then use pattern matching to alter the file paths
⁣Oisin
07570 977449
Get BlueMail for Android ​
On 4 Apr 2024, 19:28, at 19:28, "Tony Shepherd (FarmMaps NZ) via QGIS-User" <qgis-user at lists.osgeo.org> wrote:
>Hi All
>I am sure I am not the first to ponder how to deal with this.  I have
>loads,
>thousands likely, of project files in a series of folders and
>subfolders.  I
>need to move those files and folders to a new location to enable other
>staff
>to use the project files and their associated shp files, geo packages,
>rasters etc.
>Essentially, I am shifting my entire collection of GIS work to a shared
>location for others to start using, so moving from a sole operator to a
>shared environment.
>In my old MapInfo days, I would simply do a bulk search and replace
>over the
>workspace files (text-based so this is easy) and change the paths that
>need
>changing and all would be ok.
>As qgz files are not easily modified through a text editor, are there
>any
>tools out there to enable bulk changing of file paths in those files?
>Any other approaches?
>Cheers
>Tony
>Tony Shepherd
>  GeoSpatial Manager @ FarmMaps NZ & Photographer @ Shepherd Photos
>Phone - 027 435 6193  | Website -  <http://shepherdphotos.co.nz/>
>Email - Maps  <mailto:tony at farmmaps.nz> tony at farmmaps.nz  |  Email -
>Photos
><mailto:tony at shepherdphotos.co.nz> tony at shepherdphotos.co.nz
>Facebook  <https://www.facebook.com/TonyShepherdPhotos>
>TonyShepherdPhotos
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240404/3d021cb8/attachment-0001.htm>
More information about the QGIS-User mailing list
