[Qgis-user] Extracting colours from a vector file
    Alexei Schwab
    alexei at fastmail.net
    Tue Apr  9 08:06:13 PDT 2024
Hi Grant,
Not sure if this is what you mean but if you want to get the colour of a feature's symbol you can use @symbol_color in the expression builder.
So adding a "colour" column to your attributes and using field calculator to set the expression to @symbol_color will give you the colour for each feature.
It will give you a hex colour code.
If you need the RGB values, you can use  the expression:
colour_part(@symbol_color, 'red'), colour_part(@symbol_color, 'green'), colour_part(@symbol_color, 'blue')
Regards,
Alexei
On Tue, 9 Apr 2024, at 08:54, Grant Boxer via QGIS-User wrote:
> I would like to extract colours from a rule-based rendered shp file with the aim of applying these colours to a MapInfo tab file. I have tried the rgb function but that doesn’t seem to work. Anyone have any suggestions to extract the red, green and blue values?
> Cheers Grant, Perth WA
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240409/6ea49f32/attachment.htm>
More information about the QGIS-User
