[Qgis-user] A load of updates in OSGeo4W
Alister Hood alister.hood at gmail.com
Mon Apr 15 21:10:37 PDT 2024
A tip: use a new qgis profile if you try the new qt6 build.
Most plugins do not yet claim compatibility with it, so if you don't use a
new profile your plugins will be automatically disabled, then when you
reuse the qt5 build you'll need to reenable them all.
Also, be prepared to wait - it took a long time here to download the
updates.
Regards,
Alister
Date: Mon, 15 Apr 2024 01:02:46 +0200
> From: J?rgen E. Fischer <jef at norbit.de>
> To: osgeo4w-dev at lists.osgeo.org, qgis-user at lists.osgeo.org,
>         qgis-developer at lists.osgeo.org, grass-dev at lists.osgeo.org
> Subject: [Qgis-user] A load of updates in OSGeo4W
> Message-ID: <20240414230246.rvykko63wuneci3m at norbit.de>
> Content-Type: text/plain; charset="utf-8"
> Hi there,
> I just uploaded an update to OSGeo4W.   It is basically a rebuild of
> everything
> with a newer compiler (Visual C++ 2022) and updates of almost all versions.
> The update should work cleanly and cause no visual changes.
> The main change is the move from Python 3.9.18 to 3.12.3.  But there's
> also an
> update to Qt 5.15.13, OpenSSL 3.   Qt6 was also added enabling an
> experimental
> build of QGIS master with Qt6. Based on that there is also an experimental
> version of QField.
> GDAL and PROJ also were updated to the latest version.
> The legacy GRASS 7 was removed because it doesn't support Python 3.12.
> GRASS 8
> was already available and QGIS switch to it long before this update.
> Please test and report.
> J?rgen
> More details in the commit message:
> A load of updates (fixes #788, #810, #816, #819, #820, #823, closes
> jef-n/OSGeo4W#21, refs qgis/QGIS#54491, qgis/QGIS#56499)
> Highlights:
>   Switched to Visual Studio 2022
>   Qt6 6.6.3, PyQt6 6.6.1
>   Qt5 5.15.13, PyQt5 5.15.10
>   Python 3.12.3
>   OpenSSL 3.0.13
>   PROJ 9.4.0
>   GDAL 3.8.5
>   qgis-qt6-dev based on Qt6 next to qgis-dev based on Qt5
>   experimental QField based on Qt6 / qgis-qt6-dev
> Details:
>   Removed:
>     libjpeg (already replaced with libjpeg-turbo earlier)
>     python3-clcache (replaced by ccache)
>     python3-pyuv (dependency of python3-clcache)
>   Updated:
>     apache 2.4.52 -> 2.4.58
>     arrow-cpp 7.0.0 -> 15.0.2
>     boost 1.74.0 -> 1.84.0
>     brotli 1.0.9 -> 1.1.0
>     curl 8.4.0 -> 8.6.0
>     draco 1.5.6 -> 1.5.7
>     exiv2 0.27.3 -> 0.28.2
>     expat 2.2.10 -> 2.6.2
>     ffmpeg 5.1 -> 6.1.1
>     freetype 2.10.2 -> 2.13.2
>     gdal 3.8.4 -> 3.8.5
>     gpsbabel 1.8.0 -> 1.9.0
>     grass 7.8.8 -> 8.3.2
>     grass8 8.3.2 -> 99 (transitional; depends on grass)
>     gsl 2.6 -> 2.7.1+
>     hdf4 4.2.16 -> 4.3.0
>     hdf5 1.14.0 -> 1.14.3
>     kealib 1.4.14 -> 1.5.3
>     lerc 3.0 -> 4.0.0
>     libharu 2.3.0 -> 2.4.4
>     libiconv 1.16 -> 1.17
>     libjpeg-turbo 2.0.7-esr -> 3.0.2
>     libjxl 0.8.1 -> 0.10.2
>     libmysql 8.0.21 -> 8.2.0
>     libosmium-devel 2.18.0 -> 2.20.0
>     libpng 1.6.37 -> 1.6.43
>     libtiff 4.5.1 -> 4.6.0
>     libxml2 2.9.10 -> 2.12.5
>     libxslt 1.1.34 -> 1.1.39
>     libzip 1.7.3 -> 1.10.1
>     lua 5.4.4 -> 5.4.6
>     lz4 1.9.3 -> 1.9.4
>     minizip-ng-devel 3.0.2 -> 4.0.4
>     node 16.14.0 -> 20.11.1
>     oci 19.11 -> 21.13
>     ogdi 4.1.0 -> 4.1.1
>     opencl 2.0.10 -> 2023.12.14
>     openfyba-devel 20150103 -> 20240408
>     openjpeg 2.4.0 -> 2.5.2
>     openssl 1.1.1w -> 3.0.13
>     osm2pgsql 1.8.1 -> 1.11.0
>     osmium 1.15.0 -> 1.16.0
>     pdal 2.6.0 -> 2.6.3
>     poppler 23.07.0 -> 24.04.0
>     proj 9.3.1 -> 9.4.0
>     proj-data 1.16 -> 1.17
>     python3 3.9.18 -> 3.12.3
>     protobuf-devel 3.13.0 -> 25.3
>     qca 2.3.1 -> 2.3.8
>     qscintilla 2.13.4 -> 2.14.1
>     qt5 5.15.3 -> 5.15.13
>     qtkeychain 0.13.2 -> 0.14.2
>     qwc2 20220311-671a6e7 -> 20240408-3d95409
>     qwt 6.1.6 -> 6.2.0
>     saga 7.8.2 -> 9.3.1
>     saga9 9.2.0 -> 99 (transitional; depends on saga)
>     snappy-devel 1.1.9 -> 1.1.10
>     spdlog-devel 1.10.0 -> 1.13.0
>     sqlite3 3.41.1 -> 3.45.1
>     swig 4.0.2 -> 4.2.1
>     thrift 0.16.0 -> 0.20.0
>     transifex-cli 1.6.5 -> 1.6.10
>     utf8proc 2.7.0 -> 2.9.0
>     wxwidgets 3.2.1 -> 3.2.4
>     xerces-c 3.2.3 -> 3.2.5
>     xz 5.2.5 -> 5.4.5
>     yarnpkg 1.22.17 -> 1.22.21
>     zlib 1.2.12 -> 1.3.1
>     zstd 1.4.5 -> 1.5.5
>   Updated Python extensions:
>     python3-access 1.1.1 -> 1.1.9
>     python3-affine 2.3.0 -> 2.4.0
>     python3-alabaster 0.7.12 -> 0.7.16
>     python3-argon2-cffi 20.1.0 -> 23.1.0
>     python3-atomicwrites 1.4.0 -> 1.4.1
>     python3-attrdict 2.0.1 -> python3-attrdict3 2.0.2
>     python3-attrs 20.2.0 -> 23.2.0
>     python3-autopep8 2.0.1 -> 2.1.0
>     python3-babel 2.8.0 -> 2.14.0
>     python3-backports.entry-points-selectable 1.1.0 -> 1.3.0
>     python3-beautifulsoup4 4.9.3 -> 4.12.3
>     python3-bleach 3.2.1 -> 6.1.0
>     python3-certifi 2020.6.20 -> 2024.2.2
>     python3-cffi 1.14.3 -> 1.16.0
>     python3-cftime 1.2.1 -> 1.6.3
>     python3-chardet 3.0.4 -> 5.2.0
>     python3-click 7.1.2 -> 8.1.7
>     python3-cligj 0.7.0 -> 0.7.2
>     python3-colorama 0.4.4 -> 0.4.6
>     python3-coverage 5.3 -> 7.4.4
>     python3-cycler 0.10.0 -> 0.12.1
>     python3-decorator 4.4.2 -> 5.1.1
>     python3-defusedxml 0.6.0 -> 0.7.1
>     python3-distlib 0.3.2 -> 0.3.8
>     python3-docutils 0.16 -> 0.20.1
>     python3-entrypoints 0.3 -> 0.4
>     python3-esda 2.3.1 -> 2.5.1
>     python3-exifread 2.3.2 -> 3.0.0
>     python3-filelock 3.0.12 -> 3.13.3
>     python3-fiona 1.9.5 -> 1.9.6
>     python3-fonttools 4.28.5 -> 4.51.0
>     python3-future 0.18.2 -> 1.0.0
>     python3-gdal 3.8.4 -> 3.8.5
>     python3-geoalchemy2 0.12.5 -> 0.14.7
>     python3-geographiclib 1.50 -> 2.0
>     python3-geopandas 0.14.1 -> 0.14.3
>     python3-giddy 2.3.3 -> 2.3.5
>     python3-greenlet 1.1.1 -> 3.0.3
>     python3-h5py 3.8.0 -> 3.10.0
>     python3-httplib2 0.18.1 -> 0.22.0
>     python3-idna 2.10 -> 3.6
>     python3-imagesize 1.2.0 -> 1.4.1
>     python3-importlib-metadata 2.0.0 -> 7.1.0
>     python3-inequality 1.0.0 -> 1.0.1
>     python3-iniconfig 1.1.1 -> 2.0.0
>     python3-ipykernel 5.3.4 -> 6.29.4
>     python3-ipython 7.18.1 -> 8.23.0
>     python3-ipywidgets 7.5.1 -> 8.1.2
>     python3-isort 5.12.0 -> 5.13.2
>     python3-jedi 0.17.2 -> 0.19.1
>     python3-jinja2 3.1.2 -> 3.1.3
>     python3-joblib 0.17.0 -> 1.3.2
>     python3-jsonschema 3.2.0 -> 4.21.1
>     python3-jupyter-client 6.1.7 -> 8.6.1
>     python3-jupyter-console 6.2.0 -> 6.6.3
>     python3-jupyter-core 4.6.3 -> 5.7.2
>     python3-jupyterlab-pygments 0.1.2 -> 0.3.0
>     python3-kiwisolver 1.2.0 -> 1.4.5
>     python3-libpysal 4.3.0 -> 4.10
>     python3-llvmlite 0.34.0 -> 0.42.0
>     python3-lxml 4.6.2 -> 5.2.1
>     python3-mapclassify 2.3.0 -> 2.6.1
>     python3-markupsafe 1.1.1 -> 2.1.5
>     python3-matplotlib 3.5.1 -> 3.8.4
>     python3-mgwr 2.1.2 -> 2.2.1
>     python3-mistune 0.8.4 -> 3.0.2
>     python3-mock 4.0.2 -> 5.1.0
>     python3-mod-wsgi 4.9.0 -> 5.0.0
>     python3-mpmath 1.1.0 -> 1.3.0
>     python3-munch 2.5.0 -> 4.0.0
>     python3-nbclient 0.5.1 -> 0.10.0
>     python3-nbconvert 6.0.7 -> 7.16.3
>     python3-nbformat 5.0.8 -> 5.10.4
>     python3-nest-asyncio 1.4.2 -> 1.6.0
>     python3-netcdf4 1.6.3 -> 1.6.5
>     python3-networkx 2.5 -> 3.3
>     python3-nltk 3.5 -> 3.8.1
>     python3-nose2 0.9.2 -> 0.14.1
>     python3-notebook 6.1.4 -> 7.1.2
>     python3-numba 0.51.2 -> 0.59.0
>     python3-numpy 1.24.1 -> 1.26.4
>     python3-openpyxl 3.0.9 -> 3.1.2
>     python3-osmium 3.4.1 -> 3.7.0
>     python3-owslib 0.29.2 -> 0.30.0
>     python3-packaging 20.4 -> 24.0
>     python3-pandas 2.0.2 -> 2.2.1
>     python3-pandocfilters 1.4.3 -> 1.5.1
>     python3-parso 0.8.0 -> 0.8.4
>     python3-patsy 0.5.1 -> 0.5.6
>     python3-pbr 5.5.1 -> 6.0.0
>     python3-pdal-plugins 1.2.1 -> 1.3.0
>     python3-pillow 10.0.1 -> 10.3.0
>     python3-pirogue 1.2.5 -> 1.4.2
>     python3-platformdirs 2.0.2 -> 4.2.0
>     python3-plotly 4.12.0 -> 5.20.0
>     python3-pluggy 0.13.1 -> 1.4.0
>     python3-pointpats 2.2.0 -> 2.4.0
>     python3-prometheus-client 0.8.0 -> 0.20.0
>     python3-prompt-toolkit 3.0.8 -> 3.0.43
>     python3-psycopg 3.1.9 -> 3.1.18
>     python3-psycopg2-binary 2.9.3 -> 2.9.9
>     python3-pum 0.9.12 -> 0.10.0
>     python3-py 1.9.0 -> 1.11.0
>     python3-pybind11 2.6.2 -> 2.12.0
>     python3-pycparser 2.20 -> 2.22
>     python3-pygments 2.7.2 -> 2.17.2
>     python3-pymemcache 3.4.0 -> 4.0.0
>     python3-pyodbc 4.0.30 -> 5.1.0
>     python3-pyopengl 3.1.5 -> 3.1.7
>     python3-pyparsing 2.4.7 -> 3.1.2
>     python3-pyqt-builder 1.10.3 -> 1.16.0
>     python3-pyqt5 5.15.4 -> 5.15.10
>     python3-pyqt5-sip 12.8.1 -> 12.13.0
>     python3-pyqtwebengine 5.15.5 -> 5.15.6
>     python3-pyrsistent 0.17.3 -> 0.20.0
>     python3-pysal 2.3.0 -> 24.1
>     python3-pytest 6.1.2 -> 8.1.1
>     python3-pytest-cov 2.10.1 -> 5.0.0
>     python3-python-dateutil 2.8.1 -> 2.9.0.post0
>     python3-pythonqwt 0.8.3 -> 0.12.1
>     python3-pytz 2023.3 -> 2024.1
>     python3-pywinpty 0.5.7 -> 2.0.13
>     python3-pyyaml 5.3.1 -> 6.0.1
>     python3-pyzmq 19.0.2 -> 25.1.2
>     python3-qscintilla 2.13.4 -> 2.14.1
>     python3-qtconsole 4.7.7 -> 5.5.1
>     python3-qtpy 1.9.0 -> 2.4.1
>     python3-quantecon 0.4.8 -> 0.7.2
>     python3-rasterstats 0.15.0 -> 0.19.0
>     python3-regex 2020.10.28 -> 2023.12.25
>     python3-reportlab 4.0.4 -> 4.1.0
>     python3-requests 2.24.0 -> 2.31.0
>     python3-retrying 1.3.3 -> 1.3.4
>     python3-rtree 0.9.4 -> 1.2.0
>     python3-scikit-learn 0.23.2 -> 1.4.1.post1
>     python3-scipy 1.10.1 -> 1.13.0
>     python3-seaborn 0.11.0 -> 0.13.2
>     python3-segregation 1.4.0 -> 2.5
>     python3-send2trash 1.5.0 -> 1.8.3
>     python3-setuptools 67.6.0 -> 69.2.0
>     python3-shapely 2.0.2 -> 2.0.3
>     python3-simplejson 3.17.2 -> 3.19.2
>     python3-sip 6.1.1 -> 6.8.3
>     python3-six 1.15.0 -> 1.16.0
>     python3-snowballstemmer 2.0.0 -> 2.2.0
>     python3-soupsieve 2.0.1 -> 2.5
>     python3-spaghetti 1.5.3 -> 1.7.5.post1
>     python3-spglm 1.0.8 -> 1.1.0
>     python3-sphinx 3.3.0 -> 7.2.6
>     python3-splot 1.1.3 -> 1.1.5.post1
>     python3-spreg 1.1.2.post1 -> 1.4.2
>     python3-sqlalchemy 1.4.42 -> 2.0.29
>     python3-statsmodels 0.14.0 -> 0.14.1
>     python3-sympy 1.6.2 -> 1.12
>     python3-terminado 0.9.1 -> 0.18.1
>     python3-testpath 0.4.4 -> 0.6.0
>     python3-threadpoolctl 2.1.0 -> 3.4.0
>     python3-tobler 0.4.0 -> 0.11.2
>     python3-toml 0.10.1 -> 0.10.2
>     python3-torch 2.2.1 -> 2.2.2
>     python3-tornado 6.0.4 -> 6.4
>     python3-tqdm 4.51.0 -> 4.66.2
>     python3-traitlets 5.0.5 -> 5.14.2
>     python3-typing-extensions 4.5.0 -> 4.11.0
>     python3-tzdata 2023.3 -> 2024.1
>     python3-urllib3 1.25.11 -> 2.2.1
>     python3-virtualenv 20.5.0 -> 20.25.1
>     python3-wcwidth 0.2.5 -> 0.2.13
>     python3-wheel 0.35.1 -> 0.43.0
>     python3-widgetsnbextension 3.5.1 -> 4.0.10
>     python3-xlrd 1.2.0 -> 2.0.1
>     python3-zipp 3.4.0 -> 3.18.1
>   Just rebuilt with VS2022:
>     api-ms-win-core-path-HACK 0.0.1
>     avce00 2.0.0
>     base 1.0.0
>     bzip2-devel 1.0.8
>     cairo 1.17.2
>     entwine 3.0.0
>     fcgi 2.4.2
>     freexl 2.0.0
>     geos 3.12.1
>     gs 10.02.1
>     icu 67.1
>     imposm3 0.11.1
>     laszip 3.4.3
>     libgeotiff 1.7.1
>     libkml-devel 1.3.0
>     liblas 1.8.1
>     libpq 16.2
>     librttopo 1.1.0
>     libspatialindex 1.9.3
>     libspatialite 5.1.0
>     libwebp 1.3.2
>     mod_fcgid 2.3.10
>     netcdf 4.9.2
>     odbc-cpp-wrapper 1.1
>     pcraster 4.4.1
>     protozero-devel 1.7.1
>     qgis 3.36.1
>     qgis-ltr 3.34.5
>     qtwebkit 5.212.0-alpha4
>     qwc-services 1.3.4
>     setup 1.1.2
>     shell 99.0.0
>     szip 2.1.1
>     tiledb 2.8.2
>     wingetopt-devel 1.00
>   Repackaged/rebuilt for Python 3.12
>     python3-async-generator 1.10
>     python3-backcall 0.2.0
>     python3-click-plugins 1.1.1
>     python3-descartes 1.1.0
>     python3-et-xmlfile 1.1.0
>     python3-ipython-genutils 0.2.0
>     python3-jupyter 1.0.0
>     python3-mapproxy 2.0.2
>     python3-mypy-extensions 1.0.0
>     python3-pdal 3.2.3
>     python3-pickleshare 0.7.5
>     python3-pip 24.0
>     python3-ply 3.11
>     python3-pypdf2 3.0.1
>     python3-pypiwin32 223
>     python3-pyproj 3.6.1
>     python3-pypubsub 3.3.0
>     python3-pyserial 3.5
>     python3-pytoml 0.1.21
>     python3-pywin32 306
>     python3-rasterio 1.3.9
>     python3-remotior-sensus 0.3.5
>     python3-snuggs 1.4.7
>     python3-spint 1.0.7
>     python3-spvcm 0.3.0
>     python3-tomli 2.0.1
>     python3-webencodings 0.5.1
>     python3-wxpython 4.2.1
>     python3-xlwt 1.3.0
>   Added:
>     grass7 99 (transitional; depends on grass(8); grass 7 doesn't support
> python 3.12)
>     podofo 0.10.3
>     qca-qt6 2.3.8
>     qgis-qt6-dev (master based on Qt6)
>     qscintilla-qt6 2.14.1
>     qt6 6.6.3
>     qtkeychain-qt6 0.14.2
>     qwt-qt6 6.2.0
>     uriparser-devel 0.9.7
>     saga7 7.9.1 (old saga, just in case)
>     qfield-dev 3.2.2 (experimental; depends on very heady qgis-qt6-dev;
> TODO split the latter to minimize qfield dependencies)
>     poly2tri-devel 20240411 (qfield dependency)
>     zxing-cpp-devel 2.2.1 (qfield dependency)
>   Added python extensions:
>     python3-anyio 4.3.0
>     python3-argon2-cffi-bindings 21.2.0
>     python3-asttokens 2.4.1
>     python3-async-lru 2.0.4
>     python3-charset-normalizer 3.3.2
>     python3-comm 0.2.2
>     python3-contourpy 1.2.1
>     python3-debugpy 1.8.1
>     python3-deprecation 2.1.0
>     python3-duckdb 0.10.1
>     python3-executing 2.0.1
>     python3-fastjsonschema 2.19.1
>     python3-fsspec 2024.3.1
>     python3-h11 0.14.0
>     python3-httpcore 1.0.5
>     python3-httpx 0.27.0
>     python3-json5 0.9.24
>     python3-jsonschema-specifications 2023.12.1
>     python3-jupyter-events 0.10.0
>     python3-jupyter-lsp 2.2.5
>     python3-jupyter-server 2.13.0
>     python3-jupyter-server-terminals 0.5.3
>     python3-jupyterlab 4.1.5
>     python3-jupyterlab-server 2.26.0
>     python3-jupyterlab-widgets 3.0.10
>     python3-matplotlib-inline 0.1.6
>     python3-maturin 1.5.1
>     python3-momepy 0.7.0
>     python3-notebook-shim 0.2.4
>     python3-overrides 7.7.0
>     python3-pathspec 0.12.1
>     python3-psutil 5.9.8
>     python3-psycopg2 2.9.9
>     python3-pulp 2.8.0
>     python3-pure-eval 0.2.2
>     python3-pyarrow 15.0.2
>     python3-pycodestyle 2.11.1
>     python3-pyqt6 6.6.1
>     python3-pyqt6-qscintilla 2.14.1
>     python3-pyqt6-sip 13.6.0
>     python3-python-json-logger 2.0.7
>     python3-referencing 0.34.0
>     python3-rfc3339-validator 0.1.4
>     python3-rfc3986-validator 0.1.1
>     python3-rpds-py 0.18.0
>     python3-sniffio 1.3.1
>     python3-sphinxcontrib-applehelp 1.0.8
>     python3-sphinxcontrib-devhelp 1.0.6
>     python3-sphinxcontrib-htmlhelp 2.0.5
>     python3-sphinxcontrib-jsmath 1.0.1
>     python3-sphinxcontrib-qthelp 1.0.7
>     python3-sphinxcontrib-serializinghtml 1.1.10
>     python3-spopt 0.6.0
>     python3-stack-data 0.6.3
>     python3-tenacity 8.2.3
>     python3-tinycss2 1.2.1
>     python3-websocket-client 1.7.0
> Other changes:
> * acceptable licenses updated
> * switch to VS2022
> * add bootstrap.cmd to
>  * invoke installation of cygwin base,
>  * clone the repo
>  * build everything
> * build process installs necessary tools if necessary
>  * vs2022
>  * debug tools (for dbghelp.dll)
>  * cmake
>  * ninja
>  * ccache (supports msvc now)
>  * enables long paths on build (for Qt6 / webengine / chromium)
> * cleanups
> * PACKAGES added to package.sh to list produced packages
> * devenv replaced with msbuild
> * Update of ECWJP2SDKSetup_5.5.0.2268-Update4-Windows.zip not automatically
>   downloadable anymore (place in src/gdal/osgeo4w/gdaldeps and
>   src/gdal-dev/osgeo4w/gdaldeps)
> J?rgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstra?e 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/pgp-signature
> Desc: not available
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20240415/def72944/attachment-0001.sig
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240416/61631b84/attachment.htm>
More information about the QGIS-User mailing list
