[Qgis-user] QGIS Add Polygons Generate new OBJECTIDs
    Alexandre Neto
    senhor.neto at gmail.com
    Tue Apr 16 10:13:51 PDT 2024
I have no experience with oracle databases, but transposing the problem to
PostgreSQL, you would need to create mechanism to get the next value as a
default. In PostgreSQL, it's called a sequence. That stores the last id
used and retrieves the next value every time a new feature is created. QGIS
understand that default function and fill it down when new features are
created.
Hope it helps.
Alexandre Neto
A terça, 16/04/2024, 16:10, Kobben, Barend (UT-ITC) via QGIS-User <
qgis-user at lists.osgeo.org> escreveu:
> Hi there,
> From what I read this is about adding a database table in Oracle with data
> coming from an ArcGIS Pro Feature Table...? Not really a QGIS error or
> problem as such I think....?
> yours
> *Barend Köbben*
> On 16/04/2024, 16:14, "QGIS-User" <qgis-user-bounces at lists.osgeo.org>
> wrote:
> Hi Community
> We have rise the following question, we really appreciate your support:
> https://gis.stackexchange.com/questions/480009/maintain-objectid-for-new-added-polygons-using-qgis-to-an-oracle-geodatabase-fea
> [image: Image removed by sender.]
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240416/d377380d/attachment.htm>
More information about the QGIS-User
